Hi guys,
So my motor is on its way out so im stripping the DE+T bits as i am rebuilding and chasing for more power.
Good chance for you NA boys to get some boost into your car.
1) $500
Turbonetics T3/T04E turbo with 3" inlet.
.50 A/R
Oil cooled (no need for messy water lines)
excellent condition, no shaft play & does not blow smoke
5 bolt style rear housing with custom made dump (weld onto your own front pipe)
Rear housing has been modded to fit 38mm external gate *****may be able to supply a IW rear housing****
**pics of wastegate fitted is at the bottom**
2) $60
Custom alloy intake from TB > cooler pipe with bov mount welded on (RB style flange) sprayed black for stealth look
3) $50
Custom braided oil line to suit turbo > oil pressure sender side of engine + Tee piece fitting
4) $80
R34 GTT injectors
5) $80
R33 GTR fuel pump (great upgrade for any skyline GTS/GTST/GTT)
6) $50
600x300x75mm intercooler core, minor bent fines but can easily be fixed with pliers
7) $200
38mm turbosmart ultragate with 7psi spring + screamer (heat wrapped with exhaust wrap)
8) $30
Stock RB20/25DET manifold
9) $80
RB25DE/T Green label AFM
This kit came off a R34 GT so will be a direct bolt on to a R34 RB25DE, i assume it would be the same/similar for a R33 RB25DE.
Willing to sell as a package or parts on their own.
Package price;
Turbo,gate/screamer, custom dump, custom braided oil line for $700
At 14psi, it made 210rwkw @ 550nM of torque, tuner said there is heaps more room for power but i was limited by the stock injectors, AFM & NA compression.
Located in Sydney, Pics upon request of other items.
Postage is not a problem, contact for prices.
Video of it in action;
PM if interested.
Thanks
https://www.sau.com.au/forums/topic/316049-fs-rb25det-conversion-bits/
whats the whine in that vid? sounds like my gearbox before it lost 3rd gear :S
am slightly tempted by this though, if only i had the funds. are you going to keep the heatshielding for it? cos id be interested in that atleast as i have pretty much the same setup just internal gated. also have you got a pic of the turbonetics stamp on the rear housing? (i think thats where it is)
The heatshielding is ACL Heatshield.. not the cheapest stuff but it is excellent! eliminated around 80% of my heatsoak issues :laugh: It can be shaped to suit your application as well.
http://www.aclperformance.com.au/prod_heatshield.htm
If only money was my friend right now....
n-dawg is spot on, alot of interest on the heatshield but nothing else! LOL
whining is most likely thrust bearing on my gbox.
its a older style turbonetics so it doesn't have it on the rear housing.
haha i thought it was too, mine did it at all RPMs. and then one night it just went pop. would suggest getting it looked at unless you wanna fork out for a new box
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
