Hi All
I have a S2 RS4S. We purchased it about six moths ago. It has always bugged me that the brake lights in the tailgate dont come on, however the tail lights do. I just spent a couple of hours investigating this problem and it seems their is a duel filiment globe in the tailgate (21/5W) however whoever complied the car has modifyed the wiring so there is only tail light power going to the globe. I traced the wiring loom back to the main plug in the body of the car but cannot figure out where the brake light power has been cut. If anyone can shed some light on this issue and some advice on how to reconnect my brake lights it would be greatly appreciated.
Thanks in advance
https://www.sau.com.au/forums/topic/316215-brake-lights-in-tailgate-on-s2/
did they change the plug as well? how many wire it got?
how about the brake light on the top of tailgate? if that one is working, you can connect the side brake light to the top one, it will work.
that happened to my car as well until I bought another set of taillights which comes with the original wire from japan.
I don't know why the compliance workshop needs to do that, anyone know?
The brake light in the spoiler (top of the tailgate) works and as a last resort i may have to tap into it (however the wiring may not cope with the extra current draw). Their is only two wires in the plug at the moment, one tail light power and earth but the plug can take three wires the third being brake light. the brake light power wire is missing altogether. Did your new lights plug in and work or did you have to wire them in. Replacing the plug wont help me as i have no brake light power source in the bottom of the tailgate.
Thanks for the reply.
I am not sure of the exact rules, but importers used to do the same for r32 gtr (ie only 1 brake light on each side lights up) I assume it is an ADR requirement.
No doubt they just cut the wires or changed the globe, it would have been the cheapest and easiest option.
I have no idea what ADRs have agains double brake lights???? And I wonder if the advent of LED lights have caused a rule change
The globe is a duel filiment ie one for Brake and one lower wattage for taillights. I agree they would have cut a wire but the trouble being i cant find where they cut it. It was cut pre tailgate loom. the plug may have been replaced or a wire taken out of the terminal.
find out the easiest/quickest access point to the wiring harness and look for a cut wire. i doubt if a compliancer would waste his/her time doing it properly. just a quick snip job.
I will have a look at mine on the weekend as I too now want dual brake lights!
here's a pic of the s2 lights i imported from japan. all boxed and wrapped when i got them.
so doubt very much compliance would touch em. maybe done for some reason back in japan?
there's no + wire in the globe socket or loom socket for brake.
i'll check my car tmoz, see if there same or different.
Hi I have a 2001 S2 Stagea RS4S and I just had a look at the wiring behind the tailgate brake / parker lights and it looks to me like the brake lights has never worked, mine only has a Earth and the Parkers power wire connected, there is a third connection but it has never had a wire crimped in the lug, unless the import completely replace my wiring loom it's never worked
Phill
I am gonna suggest its a jap thing. My Pulsar has the same setup with lights inside the tailgate not actually being operable. The JDM version of this model have JUST tailights in the tailgate, but there is a quite widely known mod to get them working as tail & brake lights by using another feed for the tailights, and dragging a brake light feed from the tailgate spoiler light. AFAIK a brake light doesnt use that much current draw, and its not on for that long anyway, so I would take the feed from the high level brake light. You could always fuse it if you are too paranoid...
now this is just gonna bug us who only have the outer lights working ;)
it's easy enough to run a wire around to the top led brake light i reckon,
except that plastic trim seems pretty damn hard to get off.....got good clips.
side note.
I had the same brake light experience with my old vc commodore, bought a different socket
with the extra brake light contact, ran the extra wires to the existing setup and all good, never
blew a fuse. I also had 20 led brake light mounted on the parcel shelf.
From memory my old series 1 r31 skyline was the same, it had series 2 round lights i got of a mate
and went through the same process.
p.s.quick edit....both the r31 & vc also towed a trailer with supporting brake/parker, indicator, number plate lights.
recap never blown a fuse.
Edited by Stagea_Neo
In my experience most light circuits can take the load: in a few of my previous cars I ran all the wiring for my jet ski trailer off the drivers side tail light: never blew a fuse either...
Mine work now :P
Here's some pic's of where i fed the wire through.
Basically I spliced and soldered into the existing loom at the top brake light.
Fed power wire through with flexible aluminium wire, thinner/softer than a coat-hanger.
The brake light socket in the tailgate already had a spare terminal in it, had to push a little locking tab in so i could pull it out
just crimped my wire on to it, bent the tab back into place and wedged it back into the socket.
Trim was fairly easy to remove, plastic and metal clips behind it, be firm but gentle.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
