Need A Driver...merrylands Areas, Top Dollar For 10 Mins Drive
yeah but i'm pretty sure you are allowed to drive an unregistered car to a place specifically for work related to its repair and road worthiness aslong as it is withing a certain distance of the origin.
cant recall the details
Your right, you don't need a permit, they are only for travelling long distances without insurance/rego ect...
if it needs a blue slip you can drive it to your closest blueslip mechanic, if it needs rego you can drive it to your closest RTA. Providing you have all the documents with you that you are going to need to get blue slip/rego done.
I did it yesterday on a car without any numberplates and it sticks out like red dogs balls, I even drove past a general duties officer and he didn't do anything.
  • 1 year later...
If you know someone with a trade plate, that might help.
I drove an 8tonne truck from Auburn to Appin with a trade plate, it was passed the blue slip....... needed a new engineers cert.
waraka
can mod please edit out my mobile number in the first post, than delete this thread thanks.
getting lots of prank calls?
oh and how did it go? would have done the whole thing for 40 bucks...
Driving an unregistered and uninsured vehicle is also an offence attracting on the spot infringement notice fines of at least $1012 ($506 for being unregistered and $506 for being uninsured). If the matter goes to court, the maximum fine is $2200 for driving unregistered and $5500 for driving uninsured.
http://www.rta.nsw.gov.au/registration/oth...registered.html
Not heaps relevant, but unreg is now $516, and uninsured is also $516. and if you're a real smartass, there's a "not pay road tax" which is also $516.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
