Yay finerly got rid of my camry and got my self a 1989 R32 GTST 4 door.
IT's in good nic with a kakamoto exhasut and unkown brand pod filter and lowered. (front lookes farked as it sit way low to the rear).
Time for me to hit hidden vally and start drifitng.
https://www.sau.com.au/forums/topic/316426-got-my-new-car/
That looks ace mate.
How do you rate the performance.
Im guessing its way better than ya 31 even though that went well.
Cheers Wayne.
Oh yeah.. Welcome to the(import) 4 door club
Hi agan wayne being a while.
performance is good, I would say handling wise the chassie is stiffer then the 31 and it brakes better then the 31 (even with r33 gtst brake up grade from al)
has a bit more power to. altho im starting to hate the lag from 0 to 3k when i put the foot down.
the 31 was a good car to learn in and with some time i could have made it nice but keep getting done by the cops and it keep brakeing.
gona take it to the drags this friday and maybe drift it to.
brentt
https://www.sau.com.au/forums/topic/316426-got-my-new-car/#findComment-5180715
  • 1 month later...
Nice car did you get this off Damien??
Yea i think that was him porn*injapan on boost yea
got it dynoed the other day at 138RWKW at 14psi
and 15.3 @ 90mph before winding up the boost.
looking at a r33 turbo and r34 smic atm
Edited by redliningr31 skyline
https://www.sau.com.au/forums/topic/316426-got-my-new-car/#findComment-5265463
Yea he's a good mate of mine. Very clean car when I saw it.
Ah go manual
Also look at the VG30 turbo it has steel wheels I got 204RWKW on 16psi with AVC-R and there pretty cheap and pretty much direct replacement. Some model RB20 have a different banjo bolt but thats easy fixed some time they can sut bolt on.
I have a few supporting mods to get that figure Nistune computer,040 fuel pump, FMIC, 550cc injectors, VG30 tubo, JJR coil packs All the Dyno work was done my Keelan at Peckys.
https://www.sau.com.au/forums/topic/316426-got-my-new-car/#findComment-5269280
Yea have being happy with it when i brought it and yes it is clean.
thanks for the advice on mods. ive got a 34 smic on the way and a r33turbo. will look at the vg30 later on. def will be getting a nistune and bosh 040.
at the moment im gona concentrate on suspention as she understeers alot (found out on last drift practice and motakana).
and manual will be when i can find the cash.
https://www.sau.com.au/forums/topic/316426-got-my-new-car/#findComment-5277352
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
