I have a pair of series 2 C34 Stagea factory xenon headlighs in perfect conditon
No broken tabs or scatches. Complete with spare plugs and ballast units and globes
Replacement would be over $3K from Nissan
Sell the pair for $650
Open to offers over $500
Hi Darrin ,NOT TO BE A WANKER but i just got some from TERREN & paided $320 posted & in great con to :laugh::ninja: ,& knowing what they are NEW ,
Maybe you should sell them for $450 and make a few $$
If these were genuine xenon r34 like in my car they would be worth over a grand.
So what I am asking is cheap. I am in no rush to move them
I also have a set of non xenon lights as well for $250, actually have a full front end series 2 if someone wants it
Thanks for the $450 offer.
Hahaha chukie, "not to be a wanker"... Mine wernt in as "pristine" condition as Darrins are I think knowing how much they can be in that condition what he is asking is quite fair.
Free bump and good luck with the sale Darrin
