Dang :)
Perhaps one of the new function is causing a performance issue.
And while I'm on this, I've noticed that top 5 posters has been added to the top of the forums, not a great idea imho
i was doing a bit of server intensive work on the forums, it should all be good now.
Yeah, i'll remove the top posters, I only wanted newest members and latest threads displayed.
Christian
Its already in the mail. Otherwise if u want somethin now, u can have a TAB. Just press the key next to Q
highly un-refreshing....
what a let down :rofl:
Christian
    • I went and found the actual FSM again (Yeah, I squirreled...) Screen grab of the FSM for M35. 51PSi with engine idling.
    • I thought the same too, and more than happy for others to bring another source for what it is. Just throwing so me caution out there, as potentially an extra 30% current needed than expected.   Well worth more investigation, but right now, I'm going over my Cypher knowledge while Expendables 4 provides mundane noise in the background, ha ha!
    • You still around Terry?
    • If true then....wierd. That's a very high base fuel pressure for a shitty old early 2000s Nissan.
    • I may have my math slightly wrong, I'm not double checking that again, but the factory spec for fuel pressure is to set it with the engine IDLING (in vacuum). That spec is 51PSi while idling. So now add +10psi for atmospheric, and +7 for 7psi of boost, and we need 68psi of fuel pressure at full noise, and 51psi idling. That's according to the FSM I found last night for M35. So MINIMUM fuel pressure should be 51psi and it climbs from there.
