From a hypergear quote, standard R33 turbo + tune is $1300 (they still haven't returned my call :yes:), and GCG is about the same, depending on condition of the turbo (GCG will rebuild ANYTHING that isn't 110% condition).
Basically, ask around, you WILL need a tune after getting this done, so see who is the cheapest inc. shipping.
Here's every thing you need to know about high flow:
http://www.skylinesaustralia.com/forums/Hy...ce-t261613.html
Hyperger's standard high flow cost $960 with oil line, and PU high flows (Brand new .82 turbine housing, CHRA, big can actautor, oil line) for $1320. Lots of different combinations for specific performance needs. Garrett BB CHRA is optional. I think they currently holds the highest HP out put (290rwkws :D ) with high flowed units.
Ring Stao and discuss what you need, very nice guy to deal with.
Well it does depend, the basic R33 430HP one was $1300 from phone quote, but perhaps that wasn't counting other stuff.
Certainly you should take note of Nismoid, he's probably right for total install price inc tune etc.
That was just the turbo.
Install/tune would be anotyher $700-$1000
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
