Hey all,
Over the last few days I have noticed a massive vibration coming from the rear of the car.
Today I was changing the wheels on my car and noticed a massive amount of (vertical) play when holding the wheel at 12 o'clock and 6 o'clock position
I'm assuming that I have a rooted wheel bearing
Does anyone know a part number and a good place to purchase them from?
Cheers
Shane
https://www.sau.com.au/forums/topic/316860-r34-gt-rear-wheel-bearing/
actually....I think we just came across something cheaper (I have always bought nissan until now......4x= OUCH!)
will try and confirm and post up details
No rear option for bearings other than Nissan.
I just purchased a set of aftermarket rears for a great price of $100 each, only to find out that the listing is incorrect, and is in fact only for the gt-st etc.
Of course I found this out after pulling the old ones apart, so I had no option but to buy genuine nissan ones to replace them, at more than 3x the cost!
Mark
This IS available aftermarket. The GTR one is different. This is the bearing they sent me for the GTR which is slightly too small and lacks the handbrake braked on top.
You should expect to pay $150 or less.
I think the manufacturer is CBC bearing, but I'm not sure. And parts place should be able to look it up for you and order it. You don't need to go through Nissan.
What you will get is the cradle and bearing, so all you need to do is push out the hub centre and press it in to the new bearing. You need a press for this, don't even think about using a club hammer.
Mark.
These bearings are available from decent bearing suppliers. You will need to take your old bearing in to compare as the listing isn't correct.
They list the R34 GTT as the same bearing as an S13.
I note the bearing in your photo doesn't have the handbrake anchor cast onto the bearing housing. The aftermarket S13 bearings I bought came with the that anchor, but it isn't required as the S13 doesn't have a drum style handbrake.
You may find that you can still use the bearing even though it has the handbrake anchor, worked fine in the S13.
Cost $90 per side.
The only bearing I'm having difficulty sourcing is the R32 GTR, but I'm not giving up.
sorry to hijack the thread,
i've got an r32 gts-t rear end in my s13, if i clutch in and coast/roll along- i have excessive road noise and i think the wheels bearings in the rear have given up.
anyone know how much i should expect to pay for new bearings?
and can i replace them myself?
or
is it a mechanics job?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
