  • Replies 52
Updarte
cusco castor rods 100 bux
Stock BOV’s $100
Stock ic piping $100
Full engine wiring loom $250
Gtr computer $100
Stock radiator with shroud $150
Front hubs $250
GTR gearbox $550 crunch in to 4th (standard)
Dash $100
Gtr engine crossmemeber $200
Peddle box $120
Bear front cut ( good for rad replacement) $300
Steering column $100
Steering rack and power steering pump $250
Lower control arm $120 pair
Fuse box $80
Starter motor $150(includes wiring)
Stock turbos $400
Sold stuff
IC $200 ( jenna has already flogged this)
Front struts $50 (jenna has already flogged this)
Stock steering wheel in good nick $100
Clutch lines and slave cylinder
gear knob sold
stock air flow metres SOLD
Abs $50
Break master cylinder $150
update
brake lines $50
air con compressor $50
Stock BOV’s $100
Gtr computer $100
Front hubs $250
Dash $100
Peddle box $120
Fuse box $80
Stock turbos $400
Sold stuff
gear knob sold
Abs $sold
Break master cylinder $sold
castor rods sold
upper control arms sold
update with new prices
brake lines $50
Stock BOV’s $100
Gtr computer $100
Front hubs $250
Dash $100
Peddle box $120
Bear front cut ( good for rad replacement) $130
Steering column $80
Steering rack $150 ) 250 if you want the steering knuckles
Fuse box $80
Stock turbos $400
Sold stuff
gear knob sold
Abs $sold
castor rods sold
Stock ic pipingsold
bump + update
Bear front cut ( good for rad replacement) comes with peadle box ext and stering collum $250 ( good for a stagea manual conversion)
Stock BOV’s $100
Gtr computer $100
Peddle box $120
Steering column $80
Stock turbos $400
Sold stuff
Dash $100
Fuse box $80
brake lines $50
gear knob sold
Abs $sold
castor rods sold
Stock ic pipingsold
  • 4 weeks later...
  • 1 month later...
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
