Hey Skyline lovers,
i have 93 R33 skyline in white with genuine K's **this car has not been rebuilt** absolutly spotless not single scratch on car
still has OG tape deck,smells new
Only mods are top range Greddy Fmic kit, Xforce stainless exhaust and 18" advanti wheels
Car is very responsive and very quick, Mech A1 has long rego and i have RWC ready to go, this car would suit a new car type buyer...wont dispoint even fussiest buyers!
Be VERY QUick ph: 0409762945 and ask for robin....
https://www.sau.com.au/forums/topic/316950-spotless-r33-unmodified/
Hey Skyline lovers,
COMON PPL HAS TO SELL!
have you got any paperwork to back up the 37xxxkms, as that's a bold claim for a 17 year old car with incorrect pannel gaps?
LOL where does it have incorrect panel gaps? ur judging photos come looks car b4 you make up shit F**** noodle
drivers side front guard, bonnet, and front bar
drivers side rear quarter pannel and boot
these are just a few judging from average quality photos.
Hate to be the bearer of bad news my s2 r33 which had 200 rwkw looked as clean as yours if not better. It sold for $9500 and it was for sale for months drop ur price down to say $9000 and you might sell it key word might
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
