I have started a new topic so you all can easily see what parts I still have for sale and how much they are all now reduced to.
Rear Lower G13 Adjustable arms R32 (on right) -NEW $100
BeeR Fuel Rail RB26 blue anodized -NEW $200
2x Front 6 piston 2x Rear 4 piston Brembo monoblock Calipers off a Porsche GT3 Cup Race car + brand new dust seals still in bags - USED
+ 2x Billet Adaptors to adapt front calipers to any r32-34 Skyline
+ 2x Front 350mm heat treated disks with alloy centre hubs. - NEW $3,500
ATS Twin plate carbon fibre clutch - NEW $1800
ATS 1.5way Rear LSD R32 GTR -USED $700
Billet Steering Adaptor ALL NISSANS - NEW $70 (top)
HPI Engine Dampener Rb26 R32 GTR - NEW $250
JIC Adjustable Front caster rods R32 GTR -NEW $250
Greddy Trust T78 Turbo kit suit RB26 No turbo Included but everything else you need! Just buy a brand new TO4z any turbo with a t04 flange and your off!
Included : Stainless exhaust manifold suit RB26, Greddy wastegate, Greddy Hard alloy piping, stainless steel braided hoses, Greddy blow off valve, stainless trust head shield, all silicon joiners and hose clamps required, exhaust wrap -USED $1,400
Noltec Sway bar linkage bush kit Nissan (suits all skyline) - $50
NoltecRear lower control arm bush -R32 +300zx - NEW $60
ALSO FOR SALE BUT HAVE NOT TAKEN PICS YET:
HKS TA45 Turbo kit suit RB26
Included :Hks TA45 turbo no shaft play,HKS RB26 castiron single turbo exhaust manifold, HKS 50mm waste gate, Wasted gate dump pipe, HKS cast alloy piping needed to convert to single turbo including twin-to-single AFM-to-Turbo pipe - USED $1800
Greddy Profec Eo1 Boost controller -USED $420
R32 Crystal Red LED Taillights -NEW $250
Sard Fuel Pressure Regulator - USED in box $120
Spitfire Coils RB26 - USED in box $450
OS Giken Pull to Push clutch converter (put a push type clutch into a r33) USED in box $200
R34 GTR wheels SET OF 4 with caps In great condition, only one slight scratch with worn out - USED $1800
All items in EXCELLENT condition even if used.
Located in Sydney - Kellyville will post at buyers expense
Call Jake on 0404 080 448
[email protected]
  • Replies 40
Also have:
Silver R32 GTR bonnet with small dint $300
Silver R32 GTR boot with spoiler and badge $320
R32 GTR front indicators Pair $130
Hi,
I would like to buy the Sard fuel pressure regulator.
I'm a local and can pick up if you get back to me ASAP.
Thanks
Super Keen on the Boot and the Bonnet. Mine were stolen last week (CF Bonnet, Cwest on Boot)
Please PM /Ring me. I left my Mobile number on yours.
GTR is also Silver and these will be most welcomed.
Edited by Sinista32
  • 2 months later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
