Black Nissan Skyline GTR R32 Roller with Andra Spec 4 Point Cage & Side Intursion Bar
Unfinished project selling due to other projects
$6000.00
0401 040 547
0421 552 175
[email protected]
Please contact via email or phone the above numbers for any further questions or to arrange an inspection
https://www.sau.com.au/forums/topic/317231-nissan-skyline-gtr-32-roller/
sorry mate don't want bits lying around every where....
the whole thing has got to sell together as one
no chance on 6grand then, complete ones are now around the 10 mark.
well it already fitted out with an andra spec approved cage and is in great condition
perfect for the right person who wants to make a show car out of it
My intentions were a 10sec or less show condition streeter...
Engine is for sale separately it is a 26/30
looks like a bold in cage, cut and welded, without any proper floor bracing... wouldnt even pass cams.
your intentions are irrelivent to the asking price as well as the motor being for sale seprate.
when you come to realise 6grand is rediculouse and willing to split or even negotiate PM me.
Intentions are relevent when discussing the engine for sale and also to explain why the car has been tripped and engine out also...
The cage is welded in not bolt in
You could get Brown Davis to make a more comprehensive cage than that for a 1000 bucks.
It wouldnt be rusty and it would actually have a diagonal or 2.
Keen to know why it only has one side intrusion???
  • 3 weeks later...
Black Nissan Skyline GTR R32 Roller with Andra Spec 4 Point Cage & Side Intursion Bar (street legal, mod plate required
$6000.00
ALSO AVAILABLE TO COMPLETE THE PRJECT
RB26/30 ENGINE
The engine is unused and still wrapped up from workshop
Block has been modified for a sump adapter, decked, bored & line bored, mains have been modified for GTR bearing, ARP main studs, ARP head studs, oil gallerys have been modifed and grub screwed, sump is a custom 7L high octane, crank has been lightened balanced and grub screwed, spool rods, arias ceramic coated pistons, ACL race bearings...
Price $6000.00 not negotiable (machine work was $4500.00 alone)...
TRUST 6 SPEED DOGBOX $6000.00
  • 3 weeks later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
