i refuse to use the search function myself, so much easier to make a new thread, and then get 20 people posting "you should have used the search" "here's a thread you SHOULD have gone to, via searching for it"
You see, it's those people who make it so much easier for me to find what i was after.
https://www.sau.com.au/forums/topic/317506-r32/page/2/#findComment-5190927
let me break it down for you.
You arent exactly a regular member, so we dont know the story behind the car, why its close to being finished, what it started off like, etc etc etc. Perhaps you can sit down a nut out a long write up about everything you have done with the car.
Looks good, drift teks do look the part.
cheers mate glad to know there are some nice people on here! and Domar as for clarification what is there to say i posted a picture of my car and asking people to post up pics if they have a 32 pretty simple! if your gonna talk shit on this i dont wanna know about it as you dont know me!
and grammar thing gee's what are you a english teacher?
as for Damo if there where more people like you on here it would be a pleasure using this SA thread!
https://www.sau.com.au/forums/topic/317506-r32/page/2/#findComment-5190935
Which I did, you idiot. If you don't think the thread I posted is worth of 'r32 gtr pics' as requested, then I suggest you clarify what you want, or at least stick around the forums for half a day and find out about the threads - not seeing a sticky thread is inexcusable, so maybe you might want to try drinking a cup of 'shut the f**k up' and listen. After all, God gave man two ears and one mouth, which means you gotta listen twice as much as you speak. On that note, where did I talk shit? Aside from the 'base' comment which is pretty much guaranteed to happen when your initial post makes less than half sense...
Better check your attitude at the door mate, I don't care how old you proclaim to be, you're new here and you need to loose that chip on your shoulder.. Next time you ask for something, I wont bother.
-D
https://www.sau.com.au/forums/topic/317506-r32/page/2/#findComment-5190959
no need to get freak'n angry
1) you start a thread with 5 words none of them joining words
2) you post pictures the size of a postage stamp
3) you don't take criterciism or advice on what to call threads and forums
4) you yell and carry on at regulars
https://www.sau.com.au/forums/topic/317506-r32/page/2/#findComment-5190989
im not angry at all i came on here to see what other peoples R32 look like not deal with all this, i dont know much about this site abit of help wont come astray. im not on here to get people giving me shit over ( not put the title over 5 word) and stuff like that!
https://www.sau.com.au/forums/topic/317506-r32/page/2/#findComment-5191015
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
