  • Replies 148
Posted Images
James - I don't mind Rohan's LM, but the fact is that even though it's a limited edition and only 98 were produced, they won't appreciate at all.
Basically, what I'm saying is that it doesn't matter if it's an LM edition or a V-Spec, it's all about the condition. If I were to find a R33 GTR with low low km's and in dead stock IMMACULATE condition I'd pay up to $31-$32K knowing that I am buying a car that won't screw me over.
From what I know about this midnight purple GTR, it's clean, straight and (no offence to anyone young on here) hasn't had any young owners. The current owner is 55 years old. I'm sure you can see my point.
But, I will continue to look around for an R33 GTR (pref a V-Spec) that suits what I want.
No guarantees on a clean stock car not screwing you over... James' old R33 GTR is currently having HUGE problems, very expensive repairs needed.
I'm not sure if you are aware, but the reliability of a car comes down to how you drive it. I bet the youg kid that brought your R33 GTR James, thrashed the living shit out of it hence it has problems now.
If you find a performance car that has had little to no modifications and has had regular servicing, and has experienced a reasonable life + owner then you should be right.
Yes there is the chance that it could be a lemon, but I'd rather take my chances buying from an older owner.
According to the mechanic rebuilding it (very renowned mechanic, definitely knows his stuff), the damage is in no way down to the way it was driven. Was simply a mechanical failure.
Oil pump failed i believe, IIRC
^^Totally agree. Remember that when things go wrong on a GTR (32,33 or 34) they are go in multiples of $1000. If you have the money to maintain and repair it then go for it. If you need it checked over go to XSpeed as they are the experts with these things. No one else in Perth comes close.
Yes i understand that mechanical components on these vehicles do fail, however from a sensibility point of view, things like oil pumps and water pumps should be replaced by the new owners as soon as they acquire the vehicle.
I don't care if the seller tells me they have replaced the timing belt and water pump 5000kms ago, for my own piece of mind, I'd do it again as I am aware it is expensive to fix these cars.
By that reasoning, you should also replace all gaskets, hoses, seals, brake master cylinder, brake booster, gearbox synchros, etc... all of these things are known to go and can cause very expensive problems.
My point is you can't say a stock standard car will be more reliable than a modified car
Replace oil pump when you buy a car?? lolwut.
It's generally an engine out job unless you have appropriate tools and very small hands, but either way, it's way more labour intensive than a timing belt/water pump.
As already observed by others, you need to take the engine out on a GTR to replace the oil pump. Nice little expensive job, that one. In general, if the seller has the receipts for the work done and it is done by a reputable garage, then I would be happy to accept that - rather than spend several thousand dollars re-doing it all!
Jonn, by all means recommend a workshop with whom you have enjoyed good outcomes, but don't have a general swipe at all others. All workshops have their pros and cons. The more popular they are, the more diverse the opinions. I can assure you that Xspeed enjoy both, same as anywhere else.
Cheers. :happy:
The seller of the R34 GTR did not mkae up the story about the interstate buyer - so that GTR is now sold. Too bad I say.
I think a 33GTR would be a better option for me anyway.
Jonn - the reason I will use my mechanice is because my brothers have known him for 10+years and I've know him for 3+years, I trust him, and from the presentation of his workshop and the way he treats his customer's & their cars, I know he won't screw me around when we inspect it or service it.
Canute - the reason I say I would want to replace the oil pump is for peace of mind. I have known a few new owner's of R33 GTR's who have had the oil pumps fail shortly after purchasing. Maybe I'm just getting paranoid, maybe not. Either way, I don't want any major problems with whichever GTR i buy.
TBH dude, I would put the money you would spend on a new oil pump towards the rebuild fund and just cross the busted oil pump bridge when you get to it. Replacing an oil pump isn't cheap if you have to get someone else to do it, better off to save for the (inevitable) rebuild.
Have you looked at the BSB one at 45k? (or is it out of your price range?)
Not a VspecII but still possibly a Vspec?
I remember reading something about the rear diffuser being stolen or something...
Maybe be dodge, but its BSB :D
Edited by Ten Four
Bubba why must you assume that my foot will be welded to the firewall at all times :D
Yeah I know it may not be a cheap exercise, but yes you do have a very valid point.
How reliable are the R33 RB26's? I mean say it has a few resonable mods and is either running stock boost or slightly more than factory? And assuming you give it some curry every now and then....
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
