  • Replies 194
Eric,
You suck... you better have a good excuse for this.
Dino,
Good news, now your 1% legend, turn up today to collect the other 99%. Don't turn up and well, don't think I can say on these forums what wwe will call you!!!
All,
Have been looking forward to this cruise for ages, will be good. Make sure you bring you camera's! And as brendanf said, H2O is a highly recomended comoditity (Forcast is for 38 degrees).
At this stage Putty rd is still open!!!
See you all at macca's
Dan.
0414 940 938
Originally posted by Majanal
Dino,
Dan, after attending a compulsory function with the Director - Social and Cultural Affairs I was toying with the idea of jumping on the bike and catching you guys. However, the idea of jumping in the pool first was my downfall and from that point I settled on the 1% legend status. :)
Hope you all had a hoot. :D
Top Day fellas - A big thanks for Dan's legendary organisaiton.
The old man was shitting himself on some of those 35kph (80kph)hairpins - Luvin It !! he he he
Prank - Dude, keep the radio mate - consider it my Donation to you for all the bucks you contributed to the club :):D
Can't wait for the next one guys - Maybe EC on the 19th hey ??
Dan, you legend. :)
Guys, fantastic day! looking forward to the next.
Black180sx, i wnt your wheels - lemme know. :D
Brendan, you serious? you rock man, thanks very much! (i'll buy you dinner at burger king next time we meet up! :D )
Dino, BLUDGER!
How Great is that road,,,,,Tons of cool corners,,,,Great big long straights,,,Hey,,,,, I beat the lot of you,,,GTS-T's RULE.........Me thinks I need a Nismo speedo,,,that go's past you know what........
Neil.
Neil, have you got the number plate UFO25T (or similar) and travel with a small horse in the back seat?
Last sunday someone mentioned that UFO25T had brought their dog and after locking myself in the toilet at the petrol station I saw a great dane? being walked.
Mark
Neil.
Neil - If / when you get the Nismo speedo - I'd be interested to know - where, when, how, etc - That'll be one of the next things for me (for the track of course) - However, I do want to see what happens when you go past you know what !
Mark,,,,,Well Yes,,,That's My plate and Monty is a Great Dane,,, He really is a cool dog,,the back seat is normallly his and if I decided to take a Piss I'd lock the door as well,,,Then again if my boy is hangin around I don't need to lock any doors.........
Him and PranK are best of buddy's,,,,He Loves the Pres,,,,,
Neil...
tops day thanks dan,
just got home after eating chees and drinking scotch for most of the night (god i love that cheese place)
i love the hunter its all about getting pissed and having a good time
drive was fun but the ***n heat jesus it was crazy
eastern creek mmmmmm sounds like fun
and whats with women and telling me to slow down on the corners
pete
Guy's no way Monty could have come today,,,,shit,,, how HOT was it....He would have had to sit outside,,,watching one of us eat while the other 1/2 ate.....
How quick are GTS-T's,,,,we own Missiles....
Neil.
Hey Guys,
Thanks for the praise.
Thanks also to all that turned up, wouldn't quite have been as much fun without you guys.
If anyone is thinking of going back up there then be sure to let me know... as I said it is my fav road.
I took some piccy's and will post them this arvo hopefully.
Should have come for the wine and cheese, but hey... was a fun trip home with prank and ndr.
Dan.
I think that's the speed limiter function - I was originally considering removing mine, but had her re-programmed to have the limit removed instead:D
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
