  • Replies 66
GT-Ricer, alls well that ends well, its good to see you are happy, and that the car is smoother than stock for you :sick:
Whatever you do, dont sell it for a 911....no seriously, good look with it all :)
Edited by Martin Donnon
Not bad for a tuner who makes under-researched and underdeveloped mods on a shoe-string budget!
Correct, not bad, but it took time, money and effort on everybody's part.
Relative to big budgets run by major car manufactures anything else done by aftermarket tuners
no matter how good they are or how ambitious, will always be classified as "shoe string budget".
It is not an insult but a fact and in this case a compliment :P
Thank you for pointing it out.
GT-Ricer, alls well that ends well, its good to see you are happy, and that the car is smoother than stock for you :P
Whatever you do, dont sell it for a 911....no seriously, good look with it all :P
Thanks Martin, I jumped the gun a bit by wanting to pass on the goods news to my mate, 09GTR.
The car is good again and whether I sell it or keep it I wanted to make sure that it is perfect
and I am not passing on any lingering issues to the next guy.
This is quite the opposite to what some knockers acused me of. Unbelievable!
Edited by GT-Ricer
Of course, unbelievable, how dare anybody else question you Rafal, and the misleading advertising.
Its clearly much easier to knock people like me, and accuse me of "tall poppy syndrome" - it was never even considered. If being 30, university educated and on 6 figure salary makes me prone to "tall poppy syndrome" attacks then let it be.
Filling your tranny with Willal TF is warranty voiding act so your advertising is false, and this entire forum thread was about non-smooth take-offs since you filled it up with Willal - TF - so a logical conclusion was that your car is not the best GT-R around, but it may have the best rear seat.
You are clearly not very smart if you reckon you'd never sell my your car - I really wonder how will you ever possibly id me. I could be the first guy inspect your car - or I could be 5th person pay you a visit - you'll never know, but what I know is that person like you knocking and down-talking another poster for driving an R33 does not deserve any respect.
Let the forum members decide who has more integrity.
But just to make sure you don't get panicky and have sleepless nights - I DO NOT intend to inspect your car or come anywhere near you, so nothing to worry. Just wanted to make sure you know, I was just making a point based on your statement.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
