Stagea Parts For Sale
DaveB
 Share
Hi all,
I have some Stag' parts which I have collected and now need to move to make space. Some parts are left over from upgrades, some are parts which I never got around to installing.
Prices and pic's; postage prices not worked out yet. Whatever is left in a week or so I will eBay.
Stock NEO coilpacks, 'silicone fix' done, 2 with rubber insulators cut short for another project... $50 all 6
Stock NEO coilpack harness. 1 or two plugs have a broken clip (see second image) so they don't 'click' but they are still a tight fit; cheap repair if your loom has had it. $25
Series 1/Neo rocker cover with textured black finish & Stagea emblem (I say series 1 because it does not have the extra pair of threads to take the rubber hose at the rear of the rocker cover which is present on NEO engines, however it fit fine on my NEO and I just let the hose sit there without bolts). May require slight straightening at one end where it has been a little bent; nothing serious. Bargain $75
Series 2 auto wheel with tiptronic buttons. Wheel only, no airbag module/plastic covers. Has some marks which I have tried to represent as accurately as possible in the pictures. $100 ono
Gabriel 143057 strut mount dust boot and bump stop kits, 2 of, as new. Test fitted but not used. Missing only a standard cable tie each, but come with two extra Monroe "strut mate" bump stops each. Cost ~$60 each from Superchep. Suit Commondoor? $20 each
Pair Kelpro steering rack boots (not for Stagea?) SRB-003 new - pair $10
Series 1 RS-Four auto complete ATTESA assembly, including working pump, and mounting frame. Note: The ATTESA accumulator unit is lacking some charge and will probably cause your ATTESA relay to click, often, as it is off my series 2. You just need to get it recharged. I have been quoted between $6,000 and $7,000 for this assembly new from Nissan. $50
Unknown Nissan HID ballasts w/plugs. These were 'mistakenly' given to me by the compliance workshop when I requested my HID units back. Hope someone can identify the model from the part number on the ballasts. $50 for the pair
Driver's upper door seal, good condition, guessing about 150,000K's of wear (compared to mine with the same wear/condition) - $20
Set of standard S2 RS-FourV (auto) front and rear struts, removed at 130,000K's about 3 months ago. In good working condition and gives a nice comfortable ride, but was too high for my liking (gave a ride height of about 390mm front & rear). $50
Pair of standard S2 RS-FourV (auto) rear upper arms (rear camber arms) with bushes, was in good condition but needed to go adjustable arms after I upgraded my suspension - $25 pair
Please let me know interest/ask questions by posting here or PM - I check the forums often.
thanks
DaveB
dave id say they would be s3 33 or early 34 days by the looks of the ballast... i rekn my spare globes would fit. but 99% sure they will fit a stag
does the door seal have the usual crack where the drivers window hits it when it closes? if u get me
Edited by chef_stagea
Thanks Adam. The units physically won't fit into the headlight assemblies on a S2 stag, I tried... :happy: Also the wiring is wrong; they just have two wires coming out of each unit. The globes may be the same as Stagea/Skyline (Phillips D2R), I haven't tried. I could give it a shot.
Hopefully you can get an idea in the pic' of the condition of that part of the seal; but from memory there are no tears; might be a bit scuffed around the area you describe though (like the one on my car is). I bought this seal because I needed to replace the LOWER half of my seal, which *is* torn; I ended up with the upper seal by mistake. I'll get you a more detailed pic' tonight.
Edited by DaveB
Here's a higher detail close-up of the rubber seal showing where the windows meet the seal; hopefully it's clear enough to see that there are no tears, but is a little scuffed (as is the seal on my car). I treat it with some rubber/vinyl restorer and it's all but unnoticeable.
Update on what's still available,
  • Stock NEO coilpacks, 'silicone fix' done, 2 with rubber insulators cut short for another project... $50 all 6 - 4 left with insulators, sell all 4 for $40
  • Stock NEO coilpack harness. 1 or two plugs have a broken clip (see second image) so they don't 'click' but they are still a tight fit; cheap repair if your loom has had it. On hold for another member, I just have to get around to calling him and arranging another time (sorry been away!)
  • Series 1/Neo rocker cover with textured black finish & Stagea emblem SOLD
  • Series 2 auto wheel with tiptronic buttons. Wheel only, no airbag module/plastic covers. Has some marks which I have tried to represent as accurately as possible in the pictures. $100
  • Gabriel 143057 strut mount dust boot and bump stop kits, 2 of, as new. Test fitted but not used. Missing only a standard cable tie each, but come with two extra Monroe "strut mate" bump stops each. Cost ~$60 each from Superchep. Suit Commondoor? $20 each
  • Pair Kelpro steering rack boots (not for Stagea?) SRB-003 new - pair $10
  • Series 1 RS-Four auto complete ATTESA assembly, including working pump, and mounting frame. Note: The ATTESA accumulator unit is lacking some charge and will probably cause your ATTESA relay to click, often, as it is off my series 2. You just need to get it recharged. I have been quoted between $6,000 and $7,000 for this assembly new from Nissan. $50
  • Unknown Nissan HID ballasts w/plugs. These were 'mistakenly' given to me by the compliance workshop when I requested my HID units back. Hope someone can identify the model from the part number on the ballasts. SOLD pending payment - PS. these are apparently off a Cima
  • Driver's upper door seal, good condition, guessing about 150,000K's of wear (compared to mine with the same wear/condition) - $20
  • Set of standard S2 RS-FourV (auto) front and rear struts, removed at 130,000K's about 3 months ago. In good working condition and gives a nice comfortable ride, but was too high for my liking (gave a ride height of about 390mm front & rear). $50
  • Pair of standard S2 RS-FourV (auto) rear upper arms (rear camber arms) with bushes, was in good condition but needed to go adjustable arms after I upgraded my suspension - $25 pair
thanks
DaveB
Edited by DaveB
  • 1 month later...
  • 2 months later...
  • Stock NEO coilpack harness. 1 or two plugs have a broken clip (see second image) so they don't 'click' but they are still a tight fit; cheap repair if your loom has had it. was on hold for another member, I just have to get around to calling him and arranging another time (sorry let me know if you still want this Jamie)
  • Series 2 auto wheel with tiptronic buttons. Wheel only, no airbag module/plastic covers. Has some marks which I have tried to represent as accurately as possible in the pictures. Good condition overall. $100
  • Set of standard S2 RS-FourV (auto) front and rear struts, removed at 130,000K's about 3 months ago. In good working condition and gives a nice comfortable ride, but was too high for my liking (gave a ride height of about 390mm front & rear). SOLD
  • Pair of standard S2 RS-FourV (auto) rear upper arms (rear camber arms) with bushes, was in good condition but needed to go adjustable arms after I upgraded my suspension - SOLD pending payment
thanks
DaveB
  • 2 months later...
Update on what's still available 1/12/2010,
Still available...
  • Gabriel 143057 strut mount dust boot and bump stop kits, 2 of, as new. Test fitted but not used. Missing only a standard cable tie each, but come with two extra Monroe "strut mate" bump stops each. Cost ~$60 each from Supercheap. Suit Commondoor? $20 each
  • Series 1 RS-Four auto complete ATTESA assembly, including working pump, and mounting frame. Note: The ATTESA accumulator unit is lacking some charge and will probably cause your ATTESA relay to click, often, as it is off my series 2. You just need to get it recharged. This should be a lot cheaper than what I have been quoted for the whole ATTESA pump assembly new from Nissan (between $6,000 and $7,000). $50
Sold stuff
  • Unknown Nissan HID ballasts w/plugs. These were 'mistakenly' given to me by the compliance workshop when I requested my HID units back. Hope someone can identify the model from the part number on the ballasts. SOLD - PS. these are apparently off a Cima
thanks
DaveB
Edited by DaveB
 Share
    • Neostead, I'm looking to have a custom surround done that also has a slot for a fog light. Would you be willing to create a 3d model I can buy or create and ship me the part or even provide/sell the current model for me to modify? Cheers
    • Did some maintenance on the MX5, did the engine oil and filter which was uneventful, then I drained the coolant to put in the new reservoir and a thermostat, reservoir took 5 minutes  The thermostat, well that took.........3 bloody hours, what a job, the issue was the 3 bolts holding it on, one was easy, 2 were hidden and required a few 1/4 drive extensions, 1 more than I had, and a 1/4 swivel, which I also didn't have, and a good amount of playing contortionist  Getting the 2 unseen bolts back on was a time consuming nervous nightmare, as I couldn't see where they went there was alot of stabbing and hoping for the best, trying to line up a 8 mm bolt straight, which you cannot actually see or get a hand in there, with a 1/4 swivel in the mix was a nightmare Anyways, it's done now, all burped out, and run up to temp a few times, happily no leaks thank Jebus After the thermostat fiasco I decided I need a few mental health days away from tools before doing the rest of the servicing on it As for the Dunnydoore, it had the aircon regassed and it has a clean bill of health, thinking about taking it out on Monday for a cruise down the coast to look at some houses if weather permits
    • In other important race car news, instead of fixing the race car I changed the crank seals on the chainsaw, because wood burner Some damn tight (and lock tighted) m6 head bolts Who knew plastic crank cases were a thing! Quick tip, don't trust the youtube videos that say you can pull the old seals out with the head on in a husky 440e...not true, their crank seal tucks in behind the cover both sides. I'm not sure I'm a psychopath, but these things are damn loud....hope I can put all the bits back in the right place    Happily, it is now back to turning fallen trees into a combination of firewood logs and wood chips....just need a clear day to get into it properly
    • I've got 60L of e85 in there at the moment
    • Don't forget to make sure the tank is full to the brim before you try to replace the fuel pump too, that is an essential step.
