There seems to be a neighbourhood cat that is attracted to my skyline. I have noticed catprints all over the roof/boot/bonnet 3 times in the past 3 weeks and today I see that the motherf$#%er has pissed down the crack between my windscreen and bonnet. How can I stop the cat from being attracted to my car? Could it be something like a faint smell in my interior that attracts him/her to my car or is it just another attack on skylines. I want to stop it from happening ASAP because its putting small scratches on my paint I think and I'm sure cats piss isn't great for paintwork either.
Edited by Crackfox
https://www.sau.com.au/forums/topic/318251-damn-cats-climbing-on-my-skyline/
cats normally sit on your bonnet due to the heat from the engine (keeping them warm at night)
get yourself a car cover or get a product like this
Commercial Cat Repellents
4. One of the commercial cat repellents available is a powder called, "Shake-Away." Shake-Away bears the scent of the urine of predators that cats fear, namely, the coyote, the fox and the bobcat. This commercial cat repellent comes in a granular form, which you simply sprinkle around the problem area. The product is advertised as being organic, making it an acceptable option to use around children and pets. Nor will it harm your plants.
put it around the area were your car is and should keep the cat off your cat
try going to a play like city famers or a pet store and asking them for something similar.
more helpful advice here
http://www.google.com.au/search?client=fir...G=Google+Search
http://www.ehow.com/how_2228385_keep-cats-...e-remedies.html
http://landscaping.about.com/od/pestcontro..._repellents.htm
http://ezinearticles.com/?30-Tips-To-Keep-...n&id=598141
Edited by Kaido_RR
yeah just put a car cover over the car, or a piece of tarp or something so if the cat pisses it just runs down onto the ground and not into your cabin air intake haha.
I think the secret ingredient in Passiona is "cat-piss"
OK cheers Kaido RR that makes sense as it has definately got colder during the nights here in the past few weeks which would explain why it didnt happen before. Not surprisingly it happened again last night, and my engine would have been warm because I got home at 11:00ish, I'll have a look for some coyote urine to replace the cat urine that is on my car :)
Edited by Crackfox
Its because another cat sits on your car. Its obvious the one that pee'd on your car is beefing with the other one and marking its territory. My suggestion, wait with a water gun or a hose and spray both cats. Or let nature sort it self out.
b b gun.. problem solved.. thats how we stopd like 10 diff cats from fkn climbing on our fences and startn trouble with our old cat.
i dont mind comn round n sittin outfront to wait :D
but i take no repsonsability with dmg to paintwork for missed shots haha
Call the council and they will drop off a cat trap for you. You then buy small tins of tuna and bait the trap and start catching the neighbourhood stray cats.
When you catch one, you call the council come and get it. If it is a registered cat the owners are notified and informed. If its a stray/feral then its destroyed.
I had the same problem about 5 years ago with some old fat neighbour that was feeding stray and feral cats. They were breeding like rabits in the car bodies abandoned in his back yard. We got rid of 12 cats in 2 weeks and solved our problem.
Nothing is as angry as big feral cat in a small cage too. Feral cats are freeking psycho!
Yeh I have Cats Staying under my Car @ night specially in Winter.. sometimes they crawl on the bonnet, i can see
there footrprint. Sometimes they think it's there friend n just stand besides it. I see it sometimes just sitting next to it..
Strange.. but i Have a Black Car n it seems to attract it :)
Edited by Black_CSR
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
