Hi all
Im really new to the car world, so i need some base knowledge.
Anyway i was thinking of importing a skyline to australia but all i know is the FOB price what other prices and fees do i have to add on?
and what else do i have to know about when importing.
The FOB price was 170, 000 yen which is around $2000 in Australian.
I probably wont get one now but i would like to if i could, but i would definetely import later on, so any info now would help.
My friends Dad does Overseas trading to so i might be able to get some help with the customs and shipping hopefully.
You'll wanna look into Compliance costs, handling and shipping costs, import tax and a lot more that im not too sure about.
It should all come to a price close to the regular retail cost of the car were it an Australian build, but you will be saving if its done right
check this site out for more detailed info about importing: http://www.j-spec.com.au/
Edited by Ericjayrol
I also currently looking to import cars from Japan, cousin is living in Tokyo so he can bid auction cars for us. My cousin is working in a "Car Company" so does has a licence to bid.
Here are some useful links:
DIY Importing http://www.raws.com.au/ImportPurchase.asp#DIY
General Info: http://carizma.com.au/Pages/Import%20-%20Regulations.htm
A Government Web: http://www.infrastructure.gov.au/roads/veh...cles/index.aspx
General F&Q: http://www.prestigemotorsport.com.au/modules/wffaq/
SEVS Register http://www.raws.com.au/SEVSReg.asp?fs_Make..._Page=2#results
Good Luck. :)
Edited by JS2010
if i recall you need a license to bid... not just residence
so you'll need a licensed agent in jap.
to OP. J-specs a very good place to go for info... he has buckets of it... plus a nice nifty new site that i troll daily, look it up.
if your looking to actually import, then j-spec can help there too, there are also others like Iron Chef, Beer Baron, etc etc who are also hugely helpful.
i have a bloke at my work going the same route as this ie: i'm going for a trip to japan in august and gonna buy 8 or so cars - lanEvo, 33GTR and supra and "get em cheap n then flog em off in australia"
he doesn't want to use a broker, he wants to do it all himself, i have told him time and time again that it's NOT THAT EASY
especially when you're working for the state government at graduate level.
if only kristian could send this gent the post he showed here.
"outlook not good"
hahahha. btw - good one kris.!
Save yourself a lot of time and money and heartache and get one of the guys here[ Iron Chef etc] to do it for you. I have just had a GTR bought , and shipped here and the compliance is just about done[ DOTARS and public servants taking their time]. I am lucky that I have a friend in the business. The amount of paperwork in Japan and here and shipping is enormous, so in the long run get somebody who does it for a living and only takes a small amount to get it for you.
Honestly, unless your in the business i have NFI why you would risk delays and problems to save $1k.
Once the car gets to Aus, its not that bad, as I've look after cleaning, customs etc, and its not hard, but is stressfull for a first timer.
The part that would scare me though is de-reg in Japan, and getting teh car on a boat.
I was a little lucky as had a good compliance shop that walked me through everything i needed. Without them i reckon the car would still be on the docks :merli:
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
