For sale:
1990 Nissan R32 4 door - Turbo manual
km's: 12x,xxx (have had it since 70,000 and most is highway km's)
The Car used to be Non-Turbo Auto, but is now Turbo Manual...the conversion was done properly and has been very reliable for the last 10,000kms. Most of the time this is just putted around as to me its just a daily As i have a track 180sx as well.
Car doesnt have HICAS at all, and driveline and brakes, 5 stud hubs are all GTST now and the diff is a stock LSD.
RB20DET
5 stud conversion
R32 GTST Brakes + Brake booster
Turbo LSD
Velour Late model seats and trims
Swapped All side glass out (as it was tinted)
3" Cat back exhaust
Manual conversion kit
th_Hawker180_R32cooler.jpgth_Hawker180_R32engine.jpgth_Hawker180_R32Front.jpgth_Hawker180_R32inside.jpgth_Hawker180_R32inside2.jpgth_Hawker180_R32rear.jpgth_Hawker180_R32Side.jpg
The Car:
1990 Nissan R32 GTS
RB20DET (originally RB20DE)
5 speed Manual (originally Auto)
Engine mods:
Stock RB20DET
Stock Turbo (genuine 55,00kms on turbo when i put it on)
GReddy Return flow Intercooler
K&N Panel filter in stock airbox
Spitfire coil packs
3" Cat back Exhaust
Walbro Fuel Pump (Genuine)
Turbo Radiator
Exedy 5 puk clutch
Electronic:
GReddy Profect Boost Controller (not setup, just using it as a guage at the moment) Boost is bleed with a bleed tap (0.9 bar)
Suspension:
KYB Lowered Struts and springs
5 stud conversion - R32
R32 LSD Auto - (originally single wheeler)
R32 GTR rear swaybar front is stock
Exterior:
Rare 4 door Type M Skirts and bibs
Dark tint all around
Tow bar, great for 6x4/motorbike trailer etc...
Interior:
Velour Late model 4 door seats out and trims (originally grand-pa spec) - these are awesome condition!
Skyline floor mats
GTST steering wheel
Blaze gearknob
The bad:
It has 2 large scratch marks from keys (both before i brought it), one on the bonnet and one down the passanger side.
Rear guards need some paint as i rolled them to suit the wider wheels.
Front bumper has scrapes on it
Car currently has Work Meisters on it, would perfer to sell with stock wheels at a cheaper price but could come with the other wheels for extra of course
Price: $8,500 FIRM with stock wheels
$9,500 FIRM with Work Meisters (Black centre 17x8 +30 and 17x9 +30)
No SWAPS, unless you have a BA Ford Ute/Sedan + money
no RWC, Photos are pretty old, can post up some new ones with the nicer seats/steering wheel as well as the current wheels.
Edited by Hawker180
Did you use the original RB20DE or drop another RB20DET in there? Is it registered with VicRoads?
Is the car currently registered? If not when did the rego expire?
What do you reckon is required for RWC?
Cheers
Its is another engine out of a donor skyline I purchased. So a stock RB20DET. New engine numbers and Turbo has properly gone through vicroads as i also did the Brakes etc... It didnt require an engineers certificate.
Still registered (rego expires in a few days, but i will renew it so it will have 12months rego on it)
For RWC im not thinking much, but its hard to day. I reguarly maintain it so i dont expect too much will be needed.
Im going to pull the clutch master off this weekend as it is leaking, so that will be fixed
Edited by Hawker180
Some decent photos, The insides of the car hasent been cleaned yet, so its just AS IS!
A few things i forgot: Brand new battery, Timing belt and water pump done at 117,000kms, clutch only 10,000kms old (Exedy 5 puk)
Edited by Hawker180
  • 2 months later...
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
