Car is a 93 R32 Skyline GTR
Build date 05/1993
Imported back in January 2008.
I am the first owner in AUS.
Car came into the country with 76,321KM on the clock, it now has 103,xxxKM.
Most of which is highway driving.
I'd like to keep it but its barely been driven over the past year due to my current situation.
I believe its also too clean/straight to be extensively modified or turned into a track hack. Regardless the cost would have been out of my budget and I wouldn't be able to enjoy it anyway.
So I've decided to let her go and focus on one car only this year.
Here's a list of a few mods the car has. Nothing special or major.
RB26DETT - 103,xxxkm
HKS air filters (09)
HKS intercooler piping
Blitz dual SBC 1bar set boost.
MINES tuned ECU (no speed cut and higher RPM limit which I'm yet to hit.....)
New water pump (08)
New Timing Belt (08)
Cometic head gasket
Factory dump pipes feed into 60mm twin front pipes and into a 3.5 collector. Currently has a 3" test pipe.
3.5" CAT back Jap brand of some sort.
Car made 212rwkw shortly after arriving into the country. Boost controller wasn't setup properly at the time, boost was about 0.6bar give or take.
Ohlins adjustable shocks on what seems to be stock springs.
Nice firm yet comfortable ride.
Sways are stock with a few new bushes here and there.
Car still handles a little boat like. More than I'd like anyway.
Factory HICAS and ATTESSA.
Kumo KU36 225/50/16 with plenty of rubber.
NISMO 320km/hr dash
NISMO gear knob not included :(
The steering wheel and original gear knob has the usual wear on it.
Looks a bit torn up but I'm sure that's normal....I dunno maybe someone can comment.
QFM race pads
Brake fluid flushed with Lubrimax fluid.
ADR approved Braided Brake lines.
Cross drilled rotors front and rear.
Pedal is much firmer and you can stop with some confidence.
There's probably more stuff but I haven't driven the car in so long.
Always serviced on time with a full syn oil, 20w50.
Asking $19,750
Price is the way it is because I'd like to avoid tyre kickers and low ballers.
Hoping the car will go to someone who can really appreciate how clean it is.
If you're serious, I'm more than happy to discuss the price and any aspects of the car further.
On with the pictures!
PM me for further details or email; niggseh at gmail dot com
https://www.sau.com.au/forums/topic/318872-qld-1993-nissan-gtr/
Mate this is my dream car! I've been keeping an eye on 32 GTRs for years, good to see them in good condition still, it's a credit to you... If this was in Perth I would jump on this!!
Good luck!
hey mate,
how come the head gasket was changed?
Cheers
Thats just like asking why the timing belt was changed at 100k..
It was just time for it to be changed. Normally when the timing belt is changed its better to change the head gasket at the same time as half the work is already done to get to it.
This will definetely sell soon !! Only if i had another 4k and wasnt going overseas lol
Where are all the serious people at :)
I don't think those who could afford to, want to at the moment.
Everyone else who wants a GTR just wants it to go fast and don't care about much else.
I blame global warming.
Patience buddy, my GTR took 7 months to sell. Doesn't help with the apparent "GFC". :(
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
