Just thought I would ask anybody if they had tried cooling their fuel before the fuel rail. Many years ago and I mean many,,,I used to build and prepare a Drag Commodore for the Castlereagh Dragway. I used to curve the fuel line into a mulitple circle type thing (like a Still) and run it in a container full of dry ice. It worked a dream. I know that Mazda's RX7's factory 12 hour team also used this method but they chilled the fuel before it got into the tank and as history goes they dominated. Could be something you Drags guy's could play with.
Neil.
https://www.sau.com.au/forums/topic/31888-fuel-cooling/
in a mild street car which most have i dont beleive the hassle of setting it up is worth while. As for more hotter setups ie drag cars or quick streeter maybe there is some sort of fuel cooling. Me personally am in the mild streeter category and although have though about some sort of fuel cooling have never gone ahead with it.
https://www.sau.com.au/forums/topic/31888-fuel-cooling/#findComment-641749
gtsm you are spot on. X5 3litre Diesels use the same cooler. Two Part numbers 13322247411 or 13327792140. They are only available ex germany but thats only a 3 to 3 week wait. $138.07 + GST.
Neil.
https://www.sau.com.au/forums/topic/31888-fuel-cooling/#findComment-643518
Neil,
I think this is a good idea.
A few blokes on SAU are using big pumps which wouldn't be helping with fuel heat, especially the people using swirlpots.
I remember seeing on TV one night that when they transport and then pump the fuel into the servo's that the fuel needs to be a certain heat so they know excatly how much they are pumping (to charge).
Fair enough it's mass volumes, but this leads me to think that fuel density is greatly effected by heat.
So I would guess that fuel density changes would have a simular effect on a motor that air density would have !!
And we all know that turbo cars hate hot air and mega hot days.
I wonder if/how this would effect the tuning ?
J
https://www.sau.com.au/forums/topic/31888-fuel-cooling/#findComment-643673
I was wondering the same thing Jay... given that tuning usually occurs on a dyno where air flow may not represent that of driving??? would be interested to know the results.
Neil, Have you got a picture of this cooler?
Dan.
https://www.sau.com.au/forums/topic/31888-fuel-cooling/#findComment-643838
meshmesh,,,the hardest bit of installing it would be actually mounting the cooler itself. The hoses are easy as,,,,you just need to run a new hose off the fuel filter outlet and a new one onto where the old hose went.
Jay and Dan,,,I can't see any reason why it would affect tuning. It's just a small version of an oil cooler,,,very non-restrictive,,,and it's fitted before the fuel rail and regulator. Dan sorry no I don't have a pic,,,just pop into a BMW dealer pull the bonnet on a diesel X5,,,,it won't take you long to see it.
I can't see a dyno picking up on it. Next time you go for a drive,,,stop and feel the fuel filter,,,,it gets bloody hot.
Neil.
https://www.sau.com.au/forums/topic/31888-fuel-cooling/#findComment-644522
My main problem with fuel is that as it heats up, the fuel pump gets noisier. It doesn't seem to affect my knock level much if at all, but I'm not sure how much power it would be robbing because of the extra heat.
If I could hook up a fuel cooler on the cheap I'd do it just to help get rid of the pump noise.
https://www.sau.com.au/forums/topic/31888-fuel-cooling/#findComment-644549
guys,
I did a fuel cooler on a KE25 strolla racecar to solve a problem,. The car had a 1.8 turbo off a jap sillycar. the fuel kept vaporising due to heatsoak. the frontcut i got the driveline out had AIRCON. I got some fuel line and ran it paralell with the input of the aircon just b4 it hit the cabin. I wrapped heaps of insulation and it worked very well....almost to well as sometimes there would be ice on the rail after the cooler. I cant say I have had a close look at a skylines fuel and aircon systems, but it is possible. I also ran the cabin cooler in the glovebox and kept my water cool. to find the right pipe just run your aircon and its the only cold pipe under the bonnet. I also recommend the whole system on the cold side be insulated with double foilback insulation.
Just thought you might like another way.
Mal
https://www.sau.com.au/forums/topic/31888-fuel-cooling/#findComment-644745
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
