Hey all
Not sure if i should post this in this section but i figured im in SA so this mite be the rite place? For the last few months i have been trying to find an Adult Plumbing Apprenticeship (maintenance plumbing) but am having a hard time getting one. I have done 2 lots of work experience ( a week each time) which was a complete waste of my time and am now running out of ideas of where to look. So in saying that i thought id give SAU a try and see if any fellow members could help me out =). I know there must be at least one plumber on hear or some one that knows some one that may be able to help me get an apprenticeship. So please if you can help me in any way i would appreciate it. Oh and this could lead to a carton of beer in return if i get one :(
Cheers Allan
https://www.sau.com.au/forums/topic/318890-plumbing-apprenticeship/
haha madaz funny as :cool: and yeah i have been signed up with taps since about February with no luck i did a weeks work experience through them and got a good reference but no apprenticeship :). I also tryed Peer but they were not much help either.... Thanks for the speedy replies :)
go onto seek and type in plumbing. ring around for people looking for plumbers, tell them you are interested in working for them. ask them where they source their apprentices from. if your lucky, instead of going through a training scheme, they may take you on themselves. it cant hurt to ask, and you may get lucky.
good luck
Cheers Jeriatric ive been doing that with not much luck. There's gota be somewhere out there that will take me on sooner or later i guess. I think its just gona be one of those things where its who ya know....
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
