1Make: Nissan
Model: R32 GTST
Milage: 160k~
Transmission: Manual
Colour: Metalic Black
Currently registered? rego till december
Price: $11,000
Contact: - PM or sam.parsons83 at live.co.uk
Comments / Modifications:
1st owner in australia - always looked after car
Standard mods
FMIC
Apexi pod
go fast bits bleed vaulve
Sydney Kids - Whiteline Suspension set up/whiteline sway bars
cusco front upper control arms
Adjustable castor rods
17inch Volk TE37's
Slotted rotors
GTR Exhaust
interior is pretty clean, small bubble on dash as usual with R32's and steering wheel is old stock one
LED taillights
windows tinted.. 20%
gtr grille
VERTEX BODY KIT
ganador style mirrors
Carbon Fibre GTR Bonet
comes with genuine GTR Bonnet and GTR wing in metallic black.
This car had some small bits of rust and a few scratches and stone chips but all the rust got cut out and the car got resprayed about 5 months ago and is in excellent condition.
I am moving countries so I have no interest in swapping cars
https://www.sau.com.au/forums/topic/318993-black-r32-gtst/
  • 3 weeks later...
