I would suggest asking around at work. I definately sent them, and everyone else seems to have received them, I wouldn't expect yours to take this long.
Yours came in a company envelope titled to:
Leonard
39 Stenhouse Drive
Cameron Park NSW 2286
I did everyone's the same, you all got a pre printed sticker with your details on it on an envelope from PCP.
I REALLY hope they turn up today!
  • Replies 110
I"ll go hassle the warehouse boys!
IT'S IN!!!!!!! PCP!!!!!!!!!! i Got PCP!!!!!!!!!!
Thanks Doof! hehehe
I'll see you all there! Gotta come by and say hi! Does SAU have a booth anywhere?
Edited by karbonphyber
There is a small dick sucking fee. I believe it is covered more accuretly for the out of state people in our awesome Who is Wayne Prenter thread that is awesome.
also, we won't really care that much...
So I've heard. I'm laying the blame soley on Newcastle.
Will you be able to check if they arrive tomorrow morning?
we're leaving our house at 6am because we can only make the Friday, and our mail doesn't come til lunch or just after. I went up to the post office to check with them and I've also ask our neighbours in case they got them by accident.
We thought they'd be here by yesterday.
:D
Did the post office say anything useful?
I went there hoping that maybe they were there but they said because the tickets weren't sent registered post, they can't track it at all, not even look up our name, address or anything up in their system.
I don't know what else to do :D
if u wanted to call Luke about it, Nick T has his and my contact numbers.
Next year we will be using registered post... but there are extra costs involved :D
god damn newcastle, I swear to god.
I'm trying to sort something out for you now, but there isn't a whole heap we can do at the moment.
If you can wait around for the mail in the morning and just hope for the best, then that would be swell, but I don't have any idea when it would arrive, it's normally in the morning some time.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
