wrecking Nissan skyline r33 gtst 1994 with front damage need radiator support and front panels and also has damage to the right rear quarter panel will sell complete for the right price
lots of parts available just ask cheers
pics up soon
motor rb25 det $500 (bare)
gearbox $1200
pedal kit $200
tail shaft $200
diff lsd $300
stock springs & shocks $250
HKS supper dragger with hi flow cat $450
brake master cylinder $100
front calipers $150
rear calipers $100
front hubs $100
rear hubs $100
handbrake cable kit $150
front bar $150
rear bar $80
boot $70
doors $70 each
guards $70 each
left quarter panel $300
seat belts complete kit $250
front seats $200
rear seats $100
dash $170
speedometer $150
Sydney (Liverpool area)
call 0415054272
Edited by anthony84
  • Replies 46
new parts added
taillights $50 each
skyline tail light piece $50
grille $50
rear pods $70 pair
washer bottle $20
ignition barrel plus door locks $150
door trims $50 each (bare)
switches and buttons
all glass available
front calipers $150 (SOLD)
front bar $150 (SOLD)
NEW PARTS ADDED
front strut brace $100
small rear spolier $150
stock computer $150 (man)
cv joints $50 each
power window reg left hand $70
call 0415054272
Edited by anthony84
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
