  • Replies 47
See you live in Campbelltown DezertEagle, i take it you will be a regular down the 'Gong!
yeh i go to the gong everyday.... for uni and sometimes recreational purposes not actually Campbelltown does anyone know Denham Court?
anywayz had the car for a while, had two compliments from cops of
"Nice car mate" they must digg the R33's???
anywayz thanx for the comments guys!
I didnt wanna say Denham Court coz i wanted to say a place people knew of...
are u in the gong man?? there has to be some Skyline Event based between campbelltown and the gong...
Spend a bit of time in at a friends place at Thirroul, (waiting to see if i move there because of job opportunity in Wollongong) ,
...but i live in Windsor (North-west, actually more west then north :) )
