I am abouts to buy a Stagea 260RS and I am just a bit concerned with the availability of parts for this car. I know the drivetrain will not be a problem as it is just a GTR under the bonnet, but I was wondering about panels and bits that are not drive train related. Is the gray import market setup in such a way that anything is reasonably available ?
If I have a accident, I do not want to be waiting 10 weeks for a guard, bonnet etc, but I guess it should be the insurance companies problem not mine.
I do not want something so rare that I cannot get anything for it in this country.
Thanks
https://www.sau.com.au/forums/topic/31937-rare-import-and-parts/
I doubt it would be easy. Its all about what you see in the streets. If you don't see it driving around the streets, you're going to be in trouble when it comes to parts. Even 32's and 34's are a bit more difficult than common as mud 33's.
true, but you're the one going to be waiting for 10 weeks without a car, not them!
it is a hard choice isnt it. I've always liked uncommon imports for their unique value. I doubt id own one though as said parts would be too much of a problem. When i've been to any import wrecker just from looking through the warehouse i mainly only ever see s13/r32/33/34 and soarer parts and a few other bits and pieces
took me 4 months of looking to get a set of headlights for my car, once you find a place that can get what you want then you know where to go to next time! there is the japan section here post in there to see what they say as a few members live in jp.
I reckon there will be plenty of stageas around in next 12 months....but with any grey import you need patience with parts.
good choice btw
Yeah but not 260RS Stagea's. I doubt many of the panels and parts would be similar.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
