  • Replies 54
i own a R32 Nismo Edition, #219 its been resprayed midnight blue by the owner before me, but other than that inside and outside is all factory.... besides minor engine mods.
if you need any pics of special bits of the nismo 32 or lil things here and there, let me no mate. i can give you a hand going off my car.
nice to see another one geting built, this is the first ive seen bar mine.
my VIN is BNR100219 the 100 = NISMO
: D
Hey mate that's funny you say your car has been painted blue it must have been the thing to do to Nismo GTR's. I seen one for sale on yahoo a while back been painted bayside blue like mine has. Mine will be going back to gunmetal grey.
I'm happy to see any pics interior exterior dash engine bay it's always good to have something to work off if I get stuck.
My email is: [email protected]
same vin apart from 32 at the end.
I didn't realize anything of the car till I had it on the trailer heading home stopped at the shops and I had a another walk around it and thought something was up. It had no abs and no brake lines for the abs so it just hadn't been pulled off then I looked at the rear window no wiper then noticed soneone had put speakers ontop of the parcel shelf. So I thought I might so some digging on it.
Turns out to be #32. I brought it to turn into a full on track car but with only 560 built it will be worth something one day even with the engine mods it will have the engine bay will look stock
yer thats the same reason i brought mine, i only drive it maybe 1 once amonth, its just sits in the gargage under covers... haha if i was ever to paint it, it would also be goin back to gun grey, but in saying that the paint job it has atm is 100%. its a real good job.
Let me no if theres anything you need and ill send em asap.
cheers
That's funny hey same reason for buying it. I couldn't strip it out and turn it into an all out track car. I wish I got to drive mine once a month waiting for the $$$ to come better again to order the parts. If the paint it good then leave it till you want to put it back to orginal.
Will do mate any pics at all would be great
I know the feeling... I want to get sometime to work on my car. THe problem I run into is when I have time the car is at a shop, when I dont have time its in the garage...
Are you liking the NISTUNE? Gave the result and reliability your after? I am considering this is the way to go for me soon...
Yeah mate I know how you feel especially when the car sits there in front of me while I'm working on other things. But we have to earn cash to spend on these beasts.
Love nistune best ecu going around for street Nissan's even budget track cars does more than enough by far the top ecu for bang for buck.
All those Nissan ecu's people used to ditch and sell cheap not the case now when they can be turned into the same thing a power fc is.
I highly recomend them
Awesome... I am definately looking into it... My engine and box will be coming out in the next couple of months to do a turbo swap amongst other things so will need an ecu after i'm done...
Nice build!
Nice as mate what turbo's do you plan to use?? I do a stock gtr turbo rebuilt kit to steel wheel and 360 deg bearings brings them up to 500hp same as r34 gtr n1 turbos but they are ball bearing. I do them change over 1300. I'm using them on a clients rb26 in a gtst.
Thanks mate gone through many stages and ideas on how to build it and I think it will be a clean stock looking gtr with enough power to boot at 25psi
  • 4 weeks later...
LOL! I think I bought a kit from you off ebay! I can rebuild them without any hassles and get them balanced locally... I'll let you know how it goes... I truly like reading your build...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
