Hi,
Have one new OGR short shifter for r33 gtst, has been trial fitted to a vl box but dont fit as there throw is a inch differnt. so has a few scratch marks where bolts been done up.
this will fit r33 gtst gearboxs, this isnt the cheapo add on type you unbolt the whole shifter 6 bolts and replace the whole setup with this one.
$90 pickup or $10 shipping
msg me 0416250596
Travis Trayhern
https://www.sau.com.au/forums/topic/319405-org-short-shifter-r33-gtst/
if they have the same shifter setup i guess they would. all i know is it wont fit a vl or gtr as i have tried.
was orded for a r33 gtst box, who i orded it for sold his car before it arrived and now im stuck with it, hence the try's if it would fit on one of my other cars.
