I'm getting a 4 wheel alignment done tomorrow and am wondering what the best set-up for street would be?
How do skylines react to changes in toe/camber/castor and what effect does ride height have?
I always like to run a bit more castor than usual. I'm not terribly worried about feel but like the slightly lighter steering and better self-centering that comes with more castor.
As for toe/camber, I don't push it much on the road so again, I'm chasing absolute grip in lieu of driver friendliness, but what have other experienced?
Also, my car has been lowered quite a bit. Any other tips on avoiding tram tracking and the like?
I'm a bit of a alignment Nazi and have taken cars back once or twice to get a workshop to have another go. I'd rather avoid that by giving them an idea of what I want before it goes up for an alignment.
What say you?
https://www.sau.com.au/forums/topic/319508-wheel-alignment/
  • 3 weeks later...
my car is street/track
front:
camber: -3 degrees
toe: 3mm toe out
castor: 6 try 7 more the btter.
rear:
camber: near 1...depends on your wheels and fitment.
toe near: 1mm each side.
Traction rods: 5mm longer
https://www.sau.com.au/forums/topic/319508-wheel-alignment/#findComment-5250401
I would hate to see how you wear front tyres with the above wheel alignment specs. They would be great for track but terrible for street.
Mine: R33 gtst, 17x9.5" +18mm offset drifteks.
Street setting: Front.
Camber: -2deg
Castor: 6.5deg
Toe in: 2mm total (1mm per side)
Rear.
Camber: -1 to -1.5deg
Toe in: 1.5mm total (.75mm per side)
Got standard traction rods.
I work at City Suspension in Brisbane and can change my wheel alignment before going out to the track, which is nice. Those W/A specs are what I run on the street because I like to get the most out of my tyres on the street while still handling well enough for street driving.
Also, to the original poster, more positive castor will make steering heavy not lighter, and will also give greater feel and response.
https://www.sau.com.au/forums/topic/319508-wheel-alignment/#findComment-5251292
Make steering heavier?
I wound in a heap of castor on my Datto and it lightened up the steering. Maybe I was dreaming it.
I have had the alignment done. I'm not terribly happy with it. It pull right a touch but I think this may be a chassis related problem rather than a wheel alignment problem.
I need to find a workshop with a Data Liner. I want to bolt my car down and check how straight it is. I'm pretty sure it's out. The car has had a hit on the front left at some stage, but has been repaired pretty well. It was not a write-off (according to REVS).
There is a fair bit of damage on the chassis rail, which seems to be pretty common on Skylines. I'm wondering if this is due to jacking/lifting or a prang. It doesn't look compressed.
I probably should start another thread about Data Liners - it'll get lost here.
https://www.sau.com.au/forums/topic/319508-wheel-alignment/#findComment-5257219
Cowboy1600 do you have directional tyres on the front? Could you do a "left to right" with the front wheels?
If not try putting 5-10psi more pressure in the right tyre than the left. See how your pull right goes after those things.
https://www.sau.com.au/forums/topic/319508-wheel-alignment/#findComment-5258112
All the tyres were brand new and inflated equally at the time of the front end alignment.
https://www.sau.com.au/forums/topic/319508-wheel-alignment/#findComment-5258379
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
