Guys
Would anyone have the wiring diagram for the manual box on the R34 GTT. Its one of the last things to be completed on my auto to manual conversion and it would be handy to know what goes where. I am sure I saw this on the interweb somewhere but cant for the life of me find it.
Would be especially interested in hearing from any of the others who converted their auto GTTs to manual. The manual gearbox I have in the car is a R34 GTT one and NOT an R33 one like some have used and is on here in a tutorial.
Thanks in advance
Owen
https://www.sau.com.au/forums/topic/319593-r34-gtt-auto-manual-wiring-diagram/
hey Owen - seeing as nobody's been able to reply;
i take it youve been reading the DIY on the 34 manual conversion using 33 parts. ie: http://www.skylinesaustralia.com/forums/Di...&p=2606536#
I assume the plugs on the gearbox for the reverse lights and speedo are in the same physical location of the gearbox. have you obtained the correct connector plugs for the manual box? (because these will be different)
also; have you swapped your speedo cluster to a manual item?
L
  • 2 years later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
