UPDATED LIST
Genuine TRUST front bar, been stitched up a bit. $250
GTR bootlid, no wing. $50
GTR doors, no glass, no reinforcments, great for track cars. $40ea
Shell, race only non compliable shell, decent condition. come check it out. $500 (more pending what is left on it)
10 point bolt in cage, looks to be safety21, around the dash. $900
Strut brace front and rear pair $200
RB26 engine loom, perfect condition. $250
GTR castor rods adjustable ARC brand: $150
R32 quarter glass $50 each (pull em out yourself)
R32 GTR Vspec bootlip: $100
R32 GTR grill: $80
R32 GTR/gts4 coilovers JIC silver series, height adjustable $500
Fuel cell, looks to be 40 litres, $220
genuine blitz 100mm cooler, used condition, no leaks or anything like that, 3" outlets, comes with GTR mounts for rails. $450
Alloy R32 radiator $200
KKR 430 turbo, no shaft play, works well. comes with vband dump, actuator etc $500
GTR 27mm SELBYS front sway bar, adjustable, solid. $200
GTR 24mm (i think) SELBYS rear sway bar, adjustable, solid. $200
Panasport G7 rims, 17x9, +20 gtr offset, will confirm when tires are off. $1000 set.
gtr reo holes cut for n1 vents, but in tact overall. good nick. $120
s15 JAPSPEC 79,000km motor complete fan to tailshaft. all loom and ecu included. $3800
s15 rear cradle, stock arms, no diff, hubs or shafts. $350
s15 5 stud conversion, incl brakes. $1100
660cc injectors in PFI rail, suit RB26DETT great condition. $600
s15 passenger seat. $200
Wok Stich wheels. 5 spoke design, 17x8 +5 front, 17x9 +11 rear. HEAPS of dish. $1000 set
contact buckna. 0427282562
or reply here.
all parts located in brisbane. can post realistic parts.
  • Replies 50
  • 3 weeks later...
gday buckna , how are ya man , just wandering do you have a pic of the r32 gt - r skyline v spec boot lip , would be greatly appreciated and very interested man .
also if you would have a stock clutch booster assist in good condition and not leaking and a stock , in decent condition factory plastic front bar .
let me know asap
and hope to hear from you soon
cheers anthony
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
