Had a few offers which didn't come through.
Bump guys, may part trade for track car such as S13, 180, Laurel, Cefiro, Jxzxx, etc rego/defected? Doesn't bother me - car will be track car only.
  • 1 month later...
Hi SAU'ers.
Car: Nissan Skyline R32 GT-R
Year: 1992
Colour: Metallic black (looks super hot in the sun)
Drivetrain: Manual, Variable 4WD
Odometer: 98xxx
Power output: 269.4rwkw (Hi-Tech Dyno)
Rego: Till late June.
Mods: R34 GT-R Injectors (s/s casing), HKS pods, HKS cat back, s/s blitz front pipes, Cusco Zero1 coilovers 10kfront 8k rear spring rates (approx) which are great to ride on without bouncing all over the road no knocks or leaks what so ever, Work Meister S1 18x10 +13 all round which give the car a super tough stance, Nexen N6000 245/40's all round which offer a nice bit of stretch and these tyres hold the ground like sh!t to blanket 98% tread left, Car serviced every 3,000k's (every 3 months as I don't drive the car often), Running 14psi through bleed valve boost controller with no issues of boost spike, Nismo Ti gear knob, Nardi Torino steering wheel (all leather, suits the trim perfectly), Redline gearbox fluid (smurf blood :mad: ) put in maybe 2,500ks ago which won't need to be replaced for the life of the vehicle, transmax transfer case oil replaced at the same time, as well as a Excedy H/D clutch with custom 1,500kg pressure plate (easy hold 300rwkw), replaced rear main seal at the time of clutch swap and gearbox fluids change, Adjustable cam gears, Car received 100,000k service at 85,000k's (before I owned the car), which consists of water pump, timing belt, etc etc etc, dash lights, A/C lights, tripple din cluster lights are all blue however I do have all the standard globes to go with the car and if the buyer insists I can change them back, slight guard roll on the rear guards (too allow for the phat wheels) but no paint was cracked what so ever, perfect job. EBC Green stuff front pads with plenty of meat as with the standard rear pads, HID headlight kit
The trim is spotless on the whole vehicle, as with the exterior with the exception of a few tiny little defualts being a 18 year old car although is WELL ABOVE average. I am the 2nd owner of the vehicle in Australia and do currently have all of the import papers etc. I'm sure I have missed things about the car so should you have any questions don't hesitate to shoot me through a PM. I do love this car, and no I am not really in a rush if it doesn't sell so please save your time and my time and no low ball me, it is perfectly maintained, never tracked while I have owned it, it is the cleanest sounding RB26 I have heard ideling.
I am after $25,500 Firm.
Contact via PM or 0433830055.
Photos will be posted tonight once I am home.
(btw, can't actually beleive I am posting up this thread :( )
Thanks for reading,
Wayne.
awesome car champ just out of my price range though!!!!!!!!!!!!!!!1
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
