  • Replies 54
  • 4 weeks later...
hey mate i'm keen on the passenger side headlights..can u post to melbourne? can we negotiate the price? lemme know.. send me a txt or gimme a call...anytime after 3:30pm 0411795674 cheers
hey mate still have the hi flow cat? can u post to melbourne?
Had a closer look at the cat, its not in great condition, I wouldnt want to sell it. Sorry.
Headlight was sold
Hey mate what sort of condition is the P/S pump in?
what year skyline did it come off of?
Cheers, Chris
Not sure on the year sorry, but was working no problems.
Heyy mate, r33 series 1 front bar still available, If so can u ring or txt on 0434080676. Cheers gavin
Sorry sold
hi there,
I'm keen on the factory r33 strut set, i'm in Addy n need for Regency
pm me ur no. if u still have struts available
Cheers
Sorry sold
Hi Jin,
You still have the TEIN coilovers? If so can u please PM me i haven't done enough yet so can't PM u .
Thanks
Yeh I sure do, Ill PM you details
hey mate, you still got the boot? and can you pm me ur address so i can google map it
sorry should specify the red boot
Ill PM you details, I still have the red boot.
hey man i am trying to find how much you would sell the clutch pedal and clutch master cylinder you have for the r33 plus shipping to the usa...
also i was wondering if you would take the lock with the nissan logo off of the boot you have and sell that seperately!
please let me know man thanks!!! i dont have the option to pm yhet or i would i just recently purchased this skyline im part of the skylineownersusa website but it seams to be easier to find parts from this site!! thanks buddy let me know!
Clutch Pedal + Clutch master cylinder can do for $120 AUS, + postage of $55 AUS. So total $175 AUS delivered.
Sorry dont really want to remove the Nissan logo off the boot because Ive got no idea how to remove it.
Interested in the R33 S1 Radiator (the one WITHOUT damage!) Please PM if still available. Thanks.
Ill check and send you a PM, fairly sure Its still in the shed.
Hey mate,
Still got the mats? Interested if you still do
Sorry mate, they look to be sold.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
