hmm. now i'm not sure. anyway, check out the pic it should help figure it out a bit. I'm curious why you need to know anyway? if you are getting some just wait till they arrive and then have a look. if you are planning to copy them how about just paying the small amount of money they cost and giving the company that designed them some credit. when people start copying parts eventually the people who design them have to start charging more money as they get less sales volume. this in turn makes people even more likely to buy the copies and eventually the original maker can't carry on. then we loose another company that makes new innovative parts. try and get the people who copy the shit in china who have never even seen a GTR in the flesh let alone built and raced them to design an improved cam cover baffle system.....
these are not exactly a bank breaking part of an RB26 build.
PS: if not planning to copy them please excuse the rant above!
Remember curiosty killed the cat, not copying just trying to figure out the ones we have here are copies or originals. We have checked the pic you have uploaded and discussed it through. I feel the A plate cannot go through B as this will close the front end off and no oil or vapour will pass through as shown in the right top illustration in the pic above and also making any part, ie the small open ended rectangular spout, beyond the A plate would be deemed useless and not required.
Care to elaborate.
All future replies, if you cannot give a definte answer to my question then please do not reply.
I don't have time to make cheap copies for the market and agree that MOST(90%) times it is better to buy from the big name company from Japan, at times it is really hard to justify the prices.
i buy them much cheaper than whats quoted above....i think last set i bought were about $180
If this is orginal Mines product, could you possibly get me a set now at that price?
Wouldn't mind comparing the real thing with what we have here.
He quoted his BUY price... he will not sell at this price :thumbsup:
He quoted his BUY price... he will not sell at this price :(
If thats the case, then I suggest it shouldn't be boldly advertised here for the general public. General public prices (eg - Nengun prices) for us everyday folk please.
Paul couldn't possibly quote a sell price on here, because of course he is not a trader :P I guess he's just bought a lot of them for himself.
no im not selling them...merely stating that i thought the price quoted was no-where near what i paid for the 2 or 3 sets ive bought.
if anyone wants them ring CRD (no pm's to me please) as thats who i buy mine off.
maybe i get a good deal? as ive spent a lot with them over the years.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
