Hi all,
I am going to be removing the heater core/complete fan assembly from my R34 GT-R and have seen that there will be four holes that will be left in my firewall...
What would be a good way to cover up these holes? Ie - Metal plates, heat shield material etc etc...? :3some:
I have attached a pic for your reference.
Thanks for any help/info!
https://www.sau.com.au/forums/topic/320174-cover-up-holes-in-the-firewall/
what i would do :
use rubber bungs for the small round holes
then get 2 pieces of alloy cut to the oval shape of the larger hole - bolt them together through the opening so that it can be removed later. using a small amount of foam or rubber to act as a seal to the panel
buy rubber bungs from clark rubber, for the oval hole get a bigger bung, it will form to shape, exactly what ive done. works a charm
These methods sound good! Is it possible to get a photo of your setup? Would be greatly appreciated!
Thanks,
Get the ovals and circle traced and cut out of aluminium sheet, liquid nails in place to seal. Will be nice an neat. (I've even sprayed them lightly with bayside Blue :D
Nice job with the pic edit! See now THATs the sort of setup im after!!! Although i've never heard of 'liquid nails'... how do they work to seal the plates up?
Cheers
Cheers
http://www.selleys.com.au/Building-Constru...es/default.aspx
like silicone but better :D
just thinly apply to the overlap of the aluminium and stick in place over the lip of the firewall holes, will be very neat :cool:
If you can get the aluminium sheet cut as close as possible to the edge of the lipped section it will be fairly seemless.
What are you trying to acheive? Less road noise? Heat? smell?
If you just want to cover up the hole for simple reasons, use sound deadening mats... just cut and paste over the hole..
For more hardcore stuff you really should weld plates to it...
Actually, having said that you can also use thermal mats, (usually you stick this stuff around your turbo lines).. it will be pricey though.
Yeah thats not a bad idea too... hehe got a few options now. :D
Although im heading towards aluminum plates, but now have to decide whether i want to weld them or use liquid nails/sikaflex.
Cheers,
Glen
If you use sikaflex, make sure you get the heat tolerant one. There's one specifically for high temp applications @ bunnings.
Theres quite a few different sikaflex's... :blink: so which one exactly is the high temp application one that I should use?
http://www.sika.com.au/cmi/auto_products_adh.htm
Cheers,
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
