  • Replies 137
some people will tint your sunroof but Ric wont he says there is a slight chance they can burst in hot days
depends if you make ur tint out of lead, dynamite or c4... i would think that the sunroof would be the number one priority on cars with the sunroof that lack a sunroof shade....
my dads merc has tinted sunroof glass but it also comes with a soft seal that blocks all the light
-D
Last payments by 1 June 2010
UPDATE -
Thanks to those who have already made payments :ermm:
1. Ontheranch: 35% - PAID
2. Hotwire: 2 front, 20% -
3. Skylineguy19: 20% Silvia
4. Skylineguy19: 20% Falcon
5. Krishy: 35% - PAID
6. Cronic: 35% and tint removal-
7. ImportS13: vr4 20%
8. Typevu: 35%
9. typevu's mate: 35%
10.Madaz
11.Blue32:
12Pistol-Pete:35%-PAID
13.DOMN8R: 35% -PAID
14.WLD MAN: 35% R31
15:WLD MAN: 20% R33
16.Brad20:20% and rear tint removal
17.Tommmo:35%
18.Jap_Star:35%
19.Whale: 35%
20.Rush33: 35%: PAID
21.Ripp3r: 35%
22. Pyro-ns: 35% stag front windows: PAID
23. Pyro-ns: 35% Colt: PAID
24. Calais VL:35%
25.SkyHi 33: 35% and 20% rear
From now on please PM me registering your interest with the following details:
Full Name:
Ph:
Car/s to be tinted:
Tint Type: (include any removal)
Cost:
I will then respond with account details.
Thanks all,
Penny
UPDATE -
Thanks to those who have already made payments :P
8. Typevu: 35%
10.Madaz
11.Blue32: PAID (from last group buy)
14.WLD MAN: 35% R31
15:WLD MAN: 20% R33
17.Tommmo:35%
18.Jap_Star:35%
19.Whale: 35%
21.Ripp3r: 35%
24. Calais VL:35%
26. KbaTz: 20%: PAID
27. MrRS4: 2 front 35%
Full Name:
Ph:
Car/s to be tinted:
Cost:
Thanks all,
Penny
UPDATE -
8. Typevu: 35%
10.Madaz
14.WLD MAN: 35% R31
15:WLD MAN: 20% R33
17.Tommmo:35%
18.Jap_Star:35%
19.Whale: 35%: PAID
21.Ripp3r: 35%
24. Calais VL:35%
Full Name:
Ph:
Car/s to be tinted:
Cost:
Thanks all,
Penny
!!!!!!! Last payments by 1 June 2010 - NEXT TUESDAY !!!!!!!
UPDATE -
Thanks to those who have already made payments :)
8. Typevu: 35%
10.Madaz
14. Damo_R34: 20% two front
15:WLD MAN: 20% R33
17.Tommmo:35%
18.Jap_Star:35%
19.Whale: 35%: PAID
21.Ripp3r: 35%
24. Calais VL:35%
28. Amaaru: 35%
Registration cut off will be this Friday @ 2pm
If you want to join, please PM me registering your interest with the following details:
Full Name:
Ph:
Car/s to be tinted:
Cost:
Thanks all,
Penny
PLEASE NOTE: I already have 10 people PAID, so If you dont get your payment in by the due date, you will miss out!!
If you are on this list and you have changed your mind... please let me know.
i only count 9 paid Penny as Blue32 doesn't count towards the 10 needed
if you like once you have a confirm 10 people paying im happy to ask Ric if he will let the others pay on the day but they will only have 1 month to book in and get the job done??
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
