Hi all! I am trying to find nice 2nd hand wheel for my 4 stud friend...
any 4 stud 17" should be alright....
anyone have their wheels for sale?
Jeff ash if you are reding this, do you have and nice wheels at your place? I pop down to work shop but you wnarnt there but I did talk to Roy... he said talk to the man "Jash" :D
anyone know the 2nd wheel place around the perth, I tried majority of the tire places...
I hear there is 2nd hand wheel and tire place at KEWDALE anyone know their phone number or address?
much appriciated..
cheers
Joe
https://www.sau.com.au/forums/topic/3203-tires-and-wheels/
Dude,
4 Stud 17s are massively hard to find. I wish I had a buck for all the times I've been asked. I've got plenty of 16" sets about, but the only thing I've got in 17" 4 stud is a brand new set of 17x8 P1 Racing IIs which are about 7 fiddy each without tyres.
Jash
https://www.sau.com.au/forums/topic/3203-tires-and-wheels/#findComment-54841
That's is fine looking car if I may say so... I hope you looks the same... :D
well check your PM.
If you want to sell this week my offer is standing...can be negotiated I guess.
but that offer is even without looking.
I suppose to buy 17" wheel tomoro...
so let me know
cheers
Joe
https://www.sau.com.au/forums/topic/3203-tires-and-wheels/#findComment-55207
lauren-PM
I'll see you then...
cheers
Joe
ps. if I go missing tonight, the last person to see me would be you know who... if my skyline goes missing then you know who... man I am scary to make a trip to that woop woop...
I hear skyline drivers get hijacked and beat up...
I hope you are not psyco cuz I am not (even though manyh ppl disagree with me) LOL :D
https://www.sau.com.au/forums/topic/3203-tires-and-wheels/#findComment-55332
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
