was wondering if anyone has the dimensions from Hub to Hub and front to rear for the R33 or R32 rear subframe/suspension. from what i gather the GTR and GTST are dimensionally the same so either is fine.
not going to give away too much as to what its for at this stage but if anyone has one removed from a car atm or knows offhand where i could get them etc it would be great
this can be either at full droop/full compression or ride height
Cheers
  • 3 weeks later...
can anyone confirm that R32 GTR and R33 GTST are interchangeable ?
know that GTR rear ends have been used in R34's but if the mount points are the same from R32 GTR and R33 then i can jig around a cheap bare 32 subframe.
  • 2 months later...
The R33 subframe mounting points are offset by 5mm each towards the outside of the car. The anti-squat geometry is modified by lowering the front pickup point of the lower control arm by 15mm or so. (Off the top of my head; haven't measured that bit)
I have a jig for skyline subframes front and rear. It's fairly specific for the chromolly tube subframes I do but your welcome to take basic measurements of it. Mounting locations etc are all factory.
I won't send it anywhere and i don't want the geometry/pick up locations measured though as it has taken me alot of time, experiance and money to get right.
  • 4 weeks later...
  • 3 months later...
these measurements are from the middle of the bolt hole:
r32/s13
width
605mm
1070mm
length
665mm
r33
width
615mm
1085mm
length
655-660mm
i couldn't get the lengths exact with the hoops in the frame getting in the way
  • Like 1
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
