Hey stranger, not seen you for long time! Saw you at meet for 6am cruise but thought you were coming
so could catch up later, oh well, next time. Got all your wheel nuts on tight now? ha ha......
Good to see some of the original members still on here, you are one of the rare few who joined before me!
Cheers, John
G'day John, it has been a while mate, it certainly has. It was good to at least say hi face-to-face on the morning of the cruise, as brief as it was - I had commitments later that morning so unfortunately I couldn't come on the cruise proper. Ha-ha, yeah those wheel nuts are rock solid these days, I know that cause I fitted all new studs and I fit the wheel nuts on these days :happy: The 35 looks and sounds great mate, as does the 33. You, Andrew and I, and one or two others, we've been around on SAU for a while now. I still remember the days of SDU, when I was still young - late 90's.
Well im waiting for the Supra to be finished bloody picked it up around christmas, took it back for 30 psi tune and we found out the head had broken springs and stuff. So when that one is finished the 34 can get the necessary cooling system and engine rebuild done.
But yeh when your ready man on the brakes, i gotta say i have no complaints about them whatsoever, and the Supra will be getting the same package, i also have knowledge that my set came out of the same factory that builds the Patented Greddy Grex package.
Sorry to hear about the Supra, not good mate. When I was at BW last I saw a bunch of under-bonnet parts sitting in a pile and figured it wasn't good. Hang in there mate, it will get there in the end. Both cars are awesome bits of kit, a JZA80 and an R34 GT-R, spoilt for choice.
The brake package is a bargain. Half the price and the same quality as the name brand items.
brakes.... best deal I found around was the following, paid $869usd delivered for wilwood superlite 4-piston calipers, drilled 330mm rotors, metal lines, pads, bolts, & brake bracket mount.
sample - http://cgi.ebay.com.au/330mm-200SX-Skyline...=item1c11584bd6
Ive put these on my R32 gtst sedan rb26dett Im doing up as a 2-seater track. Added speedbleeders for fluid bleeding ease.
The stagea is using the r32 front gtr calipers.
Brendan, nice buy mate! That's a lot of gear for the money - especially when the AUD was in the $0.90's. The track car sounds like a lot of fun too. The brake set-up George is talking about is a little more expensive, but bang for buck is outstanding value for a 380mm rotor, huge 6-8 piston caliper, line, bracket and pad deal. And the quality is as good any of the Japanese brand name kits.
Thanks, Kel. And I hope your potential employment situation comes out the way you want it too. Fingers crossed.
Thanks, Damo. Mate if you do manage to scan it, do me a favour, don't put the photo of my face up on here - talk about a shocker!
I had a giggle :)
Hey Matty. Yeah for sure mate. I haven't driven the 33 much of late, but certainly keen to get it out. I haven't seen you since that day at Macca's - you and the missus were arriving and Kim and I were leaving. What are you driving these days? We should look at having a reunion with the old school crew.
G'day mate! Been a while but yes the car is finally at a point I can drive it whenever I want - sort of. Thanks. So how about the big 3.1L, how is she going? Does it drink E85 these days?
Ironically mine has been doing what yours was. Sitting for a long while. Mates neighbor backed into the front 1/4 panel, then got defected 5mm too low....its been sitting since. I'll have the time soon to start playing with it again but first i need to fix them minor problems :banana:
Cubes is the one to ask about energy drinks these days too :thumbsup:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
