ENGINE: *CP pistons
*Eagle rods
*Jun oil pump
*Tomei sump baffles
*Tomei headgasket
*Tomei oil feed restrictors
*custom oil drian from the rear of the head to the sump
*balanced crank
*acl race bearings throughout
*N1 water pump
*Apexi cams ( not sure what lift)
*Hks cam gears
*Hks timing belt
*Bigger Fuel pump
*700cc sard injectors
*adjustable fuel reg
*Nisstune ECU
*twin Garrett -5s
*Huge intercooler
*Alloy radiator
*Front sway bar
*middle sway bar ( in photo of interior)
*rear sway bar
*Bilstein coilovers
*torque split controller( not working at the moment will try to get fixed before sale)
*drilled rotors
*gauges, oil pressure, boost
*Alpine headunit
*Alpine 6x9s
*oil filter relocation kit
*Engineers certs prob other stuff to but cant remember everything. The car also comes with the standard gtr spoiler and Nitto Extreme drag semi slicks for the rear. Car made 340kw on 18psi with a power fc on a safe tune and made 450kwatw on 23psi, it now makes closer to 300kw with the nisstune in it, the power fc was taken out after police trouble in melbourne, which is where the car was built and made that power, if you want to ask the work shop any questions, prob should call me first jus so i can let them no what car, Ice Performace is the workshop that built it
$21,000
0411794280
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/
i thought they didnt exist any more?
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/#findComment-5229808
450 kw on 23 psi ??...sounds like a very happy dyno.
Good luck with the sale though,some nice parts on there..just the dyno figures seem a bit unrealistic .
Edited by ezy_09s
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/#findComment-5236439
so would you be up for a dyno test befor buying ?????? i dont care if i pay but i want to pick the place
Yea man sure, sorry i took a while 2 reply but i don't hav the net @ my place, jus ring me 2 set up a look c, on 0411794280
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/#findComment-5243006
yea i no, dats wat ice performance told me. Although the boost may hav bn higher i cant remember, prob more like 26 27 id say!
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/#findComment-5243023
Hey guys just letting u no that i was missinformed by the previous owner and the car made 454kw on 27psi with the nisstune. It also has a N1 oil pump not a Jun, as well as aftermarket valve springs and a recond head gbox and diff.
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/#findComment-5256427
  • 3 weeks later...
Bump
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/#findComment-5290601
  • 4 weeks later...
Where are you located mate I'm interested?
he's located in Lismore, far north coast of NSW. and he lacks having internet at home which is why his responses are sometimes non-existent.
https://www.sau.com.au/forums/topic/320400-r32-gtr-4sale/#findComment-5400869
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
