Car was imported from Japan 8 months ago with 37,000kms and now sits at 41,000kms. I'ts in very good condition and drives like a dream. The car has been modified and adjusted to perfection. It's speed and handling is amazing and will not disappoint any interested buyers. Reason of selling is that I must go to work abroad and my sister needs a car to drive while im gone and i don't think she'll like that twin plate or vice versa =P
---$25k---
Am up for swaps so show me your interests, need this gone guys!
The car has just been serviced with
- Iridium Spark Plugs
- Bendix Brake Pads
- Nissan Fuel/Oil Filters
- All Top Quality Oils
- New Nismo Super Coppermix Clutch
- Brand New 265/35 18" Tyres
Specs are as follows.
Braking & Drivetrain:
18" White Volk/Rays TE37 Wheels
Aftermarket Nismo Brake Booster
Nismo Super Coppermix Twin Plate Heavy Duty Clutch (Just Fitted 1 month ago by HyperDrive, Cost 4k for Clutch + Install)
Nismo Super Lightweight Flywheel (Also Just fitted)
Adjustable Tein Superstreet Coilovers
Engine:
Cusco Engine Strut Bar
Twin HKS Air Filters
Greddy/Trust Intercooler And Piping
ARC Oil Filter Relocation Kit
ARC Oil Catch Tank
HKS Oil Cooler
HKS Camshafts
Nismo R33 GT-R N1 Turbos
Factory Nissan ECU Rom Chipped and Tuned in Japan
Nismo Radiator Air Diversion Plate
Blitz Nur Spec 4" Full Exhaust System
All Quality Braided Oil Lines
Adjustable Nismo Fuel Pressure Regulator
Interior:
Driver and Passenger Recaro Racing Seats
Twin Defi Gauges (Boost + Water Temp)
Defi Multi Link Control Unit 2 (Gauge Controller + Data Logger)
Nismo A-Pillar Gauge Holder
Carbon Fibre Cluster Surround
Carbon Fibre Factory Din Gauge Surround
Nismo Shift Knob
Greddy/Trust Turbo Timer
HKS EVC 4 Electronic Boost Controller (0.8 Bar Low Boost 1 Bar High Boost)
Apexi Exhaust Valve Controller (Pull for stock silent exhaust note or when you want to avoid any attention)
Momo Steering Wheel
Yoshio Factory Water Temp Monitor
Sony MP3/CD Deck
Body:
Stage 21 FRP Bonnet on it's way from Japan as the original had a few deep scratches
Nismo N1 Bonnet Lip
Nismo Front Bar Spliiter
Nismo Rear Bumper
Nismo Rear Strut Bar
Led Tail Lights (Brake + Indicator)
Edited by Richy08
https://www.sau.com.au/forums/topic/320611-r33-gt-r-vspec-41000kms-370hp-atw/
Hey mate,
Would you be interested in a swap for an 04 350GT? It's red, manual, sunroof, brembo's
20 inch wheels, aftermarket exhaust, nismo rear spoiler and 44kms. My number is 0425 706470.
Cheers
nice GTR - good luck with the sale.... I am looking at selling mine soon... Just wanted to know where you got your front lip from, I am looking to replace mine prior to sale....
Thanks....
Oh, and free bump...
Thanks....
go the front lip from JS Auto imports
http://jsai.com.au/index.php?page=shop.pro...t&Itemid=29
Hey would you be interested in A swap and cash your way.
R33 gts-t and 12g you way.
Model
R33 Gts-T
Specs
Engine: Rb25Det
85000kms
KKr430 turbo
High Mount Stainless Manifold
38mm Wastegate
HKS AirFilter
Front Mount Intercooler
HKS HI Power Turbo back 3 1/2" exhaust system
Bosh 044 External Fuel Pump (in tank)
Iridiums
HKS Turbo Timer
Turbosmart Manual Boost
Bodywork:
Resprayed Into BaySide Blue R34 GTR Blue
Trust Front Bar
Trust Side Skirts
Custom Rear Bar
GTR 33 Wing
Stereo:
Alpine Cd player MP3
Pioneer Speaker
600 Watt x4 Amp
Subs X 2
Driveline:
Exedy 5 puck Clutch
Adjustable Coilovers
Edited by KF-
  • 1 month later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
