thanks dude... but i like the launch and anti lag controlss......
to bad power fc doesnt have thoes.....
any way, idle is fine now turned out to be a huge air leak from throtles.....
so does the tps do anything if you move it from position it is tuned in???
https://www.sau.com.au/forums/topic/320779-tps/#findComment-5235456
Pretty sure it's just idle, i mean once the TPS is open then it's open at whatever percentage etc (i could totally be wrong)
More so for idle i believe the adjustments have effects so if your idle is ok it should still be fine.
Doesnt sound like you made any major adjustment?
https://www.sau.com.au/forums/topic/320779-tps/#findComment-5235470
i just thought that if the tps is sending a signal because it is twisted, then the car would be trying to control the idle thinking the throtle is on all the time...
ill have a play tomorrow and see if it makes a differance..
https://www.sau.com.au/forums/topic/320779-tps/#findComment-5235473
    • My head recently blew up on the dyno, been trying to find a replacement for the last 3 months with no luck.  Does anyone know where I might be able to find one? Willing to chase down any leads at this point  Cheers
    • Waiting for a queue of Supras to get out of the way. Then the same conversion work to the box which was probably bought about the same day as you bought yours, by the sound of it. And hopefuly with enough Supras out of the way we'll finally get to do the box into the car along with the injectors and AFM so that the last 18 months of driving a highflow nearly NA can finally come to an end.
    • Got my R34 gearbox around 4-5 weeks ago. Came into some extra $$ recently and after I cleaned the mess off the notes, I thought, might as well buy that R34 box I've been pondering.  In that time I've pulled the engine out, replaced rod and mains bearings, done a few other engine things that are much easier with the engina out eg PRP oil pump upgrade, replacing wastegate coolant lines, installing Turbosmartass turbo oil pressure reg, made some mounting brackets for some of my mods that are "hard to reach", converted the R34 box to R33, put the engine and new gearbox back in the car. Plus cleaning ...Oh my god so much cleaning when doing such a project. Yep I'm a busy bee, buzz buzz. As part of the gearbox project, researched posts and found this thread (In which i nailed it for the OP), hence the post here # logical thinking.. Not all about you old boy, SOrrryyy. Dare I ask,  how's yours going ,> Or you got it done yet, and if so why didn't you post any of the tips I posted to help other members? ???
    • Seems to be the case mate , still an OK price for a grey import.
