im in for this thing ill bring my stagea out and meet some people this will be my first sau evant is exciting
Dude, I'll be working out a time that us south people should meet at APR Maccas, I'll make a post in the NSW section to get us all together at the same time. Will be good, good to see stags too :)
  • Replies 150
Maybe not this time round, Justin. I know we met last year up there; but I've been asked to help another member to look over an R34 that he's interested in this Sat morning.
If that falls through, then yes, I'll come for a drive; with tickets in hand.
Or maybe, :) someone can continue to sell Cinema Tickets for us up there and get back to me later that day eh?
list thus far
cpd
pbk1776
nismo86
doubleoverhead
dave074
08r3308
warlord
tbag
TKR
dori34
wanderer
series 6 RX7
Juz
Q9tran
SIRRB
long3
sargeRX8
gTI
Evo9
R33
35???
figjam
Goodo
me
Not to bad thus far. Have over 20 cars if all shows that says they will. but i not worried. I have done the run with 3 acrs before:) See you soon
i think i've seen ur 32 around is it parked on the street ? i think it was white near cabra rd
who:? me?
my one havn't been on the road for awhile now! been in the workshop!
p.s its black (looks very standard too) :bunny:
Me and the missus may be going, not 100% sure as my sisters birthday is also on the same day, but it doesn't start until late. :) So it should be fine
Will be at Hungry Jacks on Cabramatta Road if Longz and other people are meeting there before heading off.
Q9TRAN, are you Christy's bf? Glad to see your R32 back on the road :D
Everyone still going if the weather. Is like today??
Still worth it, if only to buy your "R32 GT-R 21st Birthday" Cinema Tickets from me :D
If it's wet, I'll be in my Silver XT Forester + new SAU shirt. :(
If you're coming back down Mac Pass under brakes, with watercourses coming across the road, try to use gears rather than heat up your rotors = hint-hint... :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
