im in for this thing ill bring my stagea out and meet some people this will be my first sau evant is exciting
Dude, I'll be working out a time that us south people should meet at APR Maccas, I'll make a post in the NSW section to get us all together at the same time. Will be good, good to see stags too :)
  • Replies 150
Maybe not this time round, Justin. I know we met last year up there; but I've been asked to help another member to look over an R34 that he's interested in this Sat morning.
If that falls through, then yes, I'll come for a drive; with tickets in hand.
Or maybe, :) someone can continue to sell Cinema Tickets for us up there and get back to me later that day eh?
list thus far
cpd
pbk1776
nismo86
doubleoverhead
dave074
08r3308
warlord
tbag
TKR
dori34
wanderer
series 6 RX7
Juz
Q9tran
SIRRB
long3
sargeRX8
gTI
Evo9
R33
35???
figjam
Goodo
me
Not to bad thus far. Have over 20 cars if all shows that says they will. but i not worried. I have done the run with 3 acrs before:) See you soon
i think i've seen ur 32 around is it parked on the street ? i think it was white near cabra rd
who:? me?
my one havn't been on the road for awhile now! been in the workshop!
p.s its black (looks very standard too) :bunny:
Me and the missus may be going, not 100% sure as my sisters birthday is also on the same day, but it doesn't start until late. :) So it should be fine
Will be at Hungry Jacks on Cabramatta Road if Longz and other people are meeting there before heading off.
Q9TRAN, are you Christy's bf? Glad to see your R32 back on the road :D
Everyone still going if the weather. Is like today??
Still worth it, if only to buy your "R32 GT-R 21st Birthday" Cinema Tickets from me :D
If it's wet, I'll be in my Silver XT Forester + new SAU shirt. :(
If you're coming back down Mac Pass under brakes, with watercourses coming across the road, try to use gears rather than heat up your rotors = hint-hint... :)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
