its there to either
1. Waste your time
2. Take more cash
3. Waste your time and take more cash,
its actually there because people found a way around the other rules so they put a new one in place. that said if you are looking for a car why would you not want a stock one to start from. at least you would not end up with a hand grenade like some kids did with the 15 yr R32 GTR..
so instead of popping off , think about it laterally for a sec. if you want something different then you pay a price to have it. fairly simple concept.
The no modifications rule is just a simple blanket ban, not taking into account that cars that age generally will have modifications done to them.
And a blanket ban just goes to show how lazy the people making up these rules are.
It is nothing like a blanket ban, it isnt targeting JDM cars they are dragged into it, so the "blanket ban" comment is it a personal thought or something you have been officially informed about.
World coming to the end and unvalidated comments mean nothing till it is proven.
Isnt that what a blanket ban is? Everything older than 1989, no modifications after 1989, and you have to prove the date of those modifications.
It doesn't even elaborate on what "no modifications" mean, since that could mean anything, like someone has mentioned before, wheels. So its a whole undefined area that just makes it harder for people to get in cars they want.
Click the link on the first page, and read it.
lol I think you'll find he did already :P
The point is that currently, the changes are not targeting us, but the wording is ambiguous enough that, if you strike the wrong DoTaRS member on the wrong day, anything non-standard could be enough to get it knocked back.
well i hate to be the bearer of bad news guys but bitching about it in a sub section of a net forum isn't going to give us our answers...
perhaps it's time we started lobbying our government for change?
seems to work in thailand...
...too soon?
...sounds to me like Canberra's pollies' revenge against summernats :blink:
yup! stop the cars coming in and it will quieten the streets down a bit - NOT!
still does not stop me grabbing 88 and older cars from NZ.
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
