hey guys,
i recently changed my cat back exhaust (from a aftermarket 3" to a different 3"), left everything from there untouched (stock dump pipe). I was fiddling around to change my dump pipe and decided to leave it for another day as it seemed i needed to take the heat shield out.
In the process of trying to loosen some of the screws on the heatshield, i took off an earthing wire but then i put it back on when i gave up for the day..
my car has always held constant 0.5bar boost, now when i drive it, 5000+rpm or so, it spikes to 0.7bar boost? any reason why its doing this? any help appreciated...
The earth in question is circled red
Edited by shaun123
https://www.sau.com.au/forums/topic/321521-boost-spike/
but i still have my stock dump pipe, wouldnt this mean that no matter how big the catback exhaust was, it'd still only flow to the stock specs?
I used to have a aftermarket 3" system on it before anyway, and i just changed it to another aftermarket 3" system...
https://www.sau.com.au/forums/topic/321521-boost-spike/#findComment-5246122
its not a spike either
a spike is if you graphed it and the graph had a sudden rise then sudden drop eg a spike
and its normal
what are you worried about
and that earth has SFA to do with anything
Edited by lachlanw
https://www.sau.com.au/forums/topic/321521-boost-spike/#findComment-5246276
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
