Ok this problem just continues and its a long story now, hope you have time to read, but who knows we might all learn something!:) Hopefully me :)
When I drive, it seems to hesitate then go, then u slow down, return throttle to idle, it dies back, then u go a bit and it hesitates, then takes off ( and i dont mean boost im talkin about 1000 to 1500 rpm area of the map) its really annoying and actually a pain to drive. you cant go over speed bumps or drive slow without it really buggin the shit outa you.
and it stalls at idle, if allowed to settle for a while. Usually the air conditioner load causes this, when u turn it off it doesnt affect it so bad. So i did all the usual checks, Ive got a Oscilloscope and ive put it on the inputs and outputs on the ecu to check everything. Ive checked the AAC solenoid, its working properly, ive checked the battery voltage, its 13.7, and fuel pressue is 33 psi. is that a bit low? Ok so next I try raising the air input a bit by winding out the manual screw and it just takes away some of the work the AAC valve does (by the way i did clean the AAC) but that still doesnt change the problem much. anyway, i thought ok ill just put an extra air solenoid in to bypass the throttle - nope that didnt work! it just doenst want to put in the extra fuel.
so then i think "ok maybe its getting air but not registering the air and therefore not putting in extra fuel! "
so i put my cro on the air sensor and its seeing the air just fine!!!
I also noticed that when the throttle idle position contact switch is made, (idle position) the ecu retards the ignition and pulls back the fuel a bit and allows the engine to come back to a 600rpm idle. If you adjust the idle switch so it is NOT made, the ecu advances the ignition and puts a bit more fuel in and the revs rise. even tho you have not opeend the throttle. the car actually came into my posession like this and its a high idle, it wont idle low, no good!
so i dunno...THEN I thought ill check the injectors and i think they could possibly do with a clean and check. anyway have not done that yet, the car's economy on the highway is good, the cruise mixture cycles just fine (on the fuel mixture meter monitor) i have another set of second hand injectors waiting to go to the shop to get ultrasonically cleaned. So anyway I then observe the fuel pressure gauge
Its then i notice that when u gently rev the motor it goes up to 44psi, and as you would expect goes up and down as it should with boost/vacumn
THEN i notice that it waits 3 seconds at 44psi, then falls back to 33psi!! everytime after the throttle is returned to idle position (idle throttle position switch contact is made) it does this! is this normal?
and its identical to the wierd hesitation fault im experiencing when driving!!??
how does it do this? cant do it with the fuel pump! cant see any electrical thing connected to the ecu that would let the ecu take control of the fuel pressure like this! what the heck is goin on?
I can tell that this lowering of the fuel pressure is playing up with the mixtures at idle and making it stall, even tho its getting enough air, its not getting enough fuel coz the pressure is too low!
so can anyone else tell me what their normal idling pressure is? and if it does this wierd thing?
hope ive explained it well enough:)
sounds pretty normal for the fuel pressure to do this. im not sure of the exact pressures but it does reduce pressure at idle as the vacuum is greater and opens up the fuel pressure regulator more. therefore when you rev a bit or under boost the regulator closes more hence increasing the pressure in the fuel rail. i am still leaning towards AFM or a boost leak in your intercooler piping or even a vac leak like an intake manifold gasket or a cracked hose.
take it to a good mechanic and get them to do an intake pressure test where they pressurise your intake tract with a harmless smoke that way you will see if there are any leaks that you need to fix.
if this doesnt turn up any leaks i would say your AFM or the wiring to the AFM are dodgy.
Ive just found that the RB20DET model has a "FPCM" function and an extra wire from the ecu that does something to the fuel pump. It cuts it back a little in voltage or something a few seconds after returning to idle position. This is definetly around the problem my car has. So it appears to be normal. So why is it making it run wierd is beyond me, and maybe this is why they dropped it on any other skyline models (you wont find it on any R33 or later)
its Terminal 104 on the ecu, goes to 0v while driving , at idle raises to 9volts. Wierd hey.
I will try the smoke in the intake tract idea, i still am not 100% sure that my intact tract is perfect, but i do notice that when i screws the idle up screw right in so it lets NO air thru, the engine will still idle and the aac valve takes over more letting more air in and if i unplug the electrical plug, boom, she stalls like it should. So no leaks after the throttle valve at least.
I am still leaning towards injectors dirty.
Starting to think this is just what happens to this system when everything gets old and tired! It just runs poorly.
It probably explains why the previous owner just had the throttle switch disabled, so it would never do this and just live with a high idle.
Found that at a fast idle (throttle open slightly) its supposed to have 3kg/cm2 fuel pressure and at idle, after 3 seconds, 2.5kg/cm2 which seems right coz that calculates to 35 and 43 psi exactly. which is what ive measured.
sucks when you find so many things in your car checks out hey, yet it runs like a dog
Think im going to get cracking on doing up a second set of injectors:)
thanks for your input PUDZ (lol)
Edited by stimps
ah and one more thing, sometimes the warning light starts flashing, but when you check the warning codes, 55 flashes up, which means all ok!!??
hey?
it starts flashing along with fuel mixture, goes off when rich, comes on when lean. yet i have not put it into mixture check mode!?
Ive got a spare ecu, tried that, same thing
ive swapped air flow meters, ecus, and TPS, *shrug*
HELP!
I am hoping to find anyone on here who knows how these crazy ecu's work in this model skyline, I'm at my wits end. I've disabled the idle control circuit, since it just won't properly do the job, and left the throttle open slightly to try to stop it stalling. Got a raised idle but it's better than stalling at the lights. But then it happened again, just slowed down to pop into a driveway then boom, stalls. Why would the ecu just shut down the engine like that?
No wonder most poeple turf out this horrible bit of shit ecu and put in programmable management!!
My auto RB25DET NEO Stagea is experiencing a stalling problem. About 50% of the time when I stop it stalls.
Pretty anoying, the mechanic said the battery was going down to 9V when starting.
So today I bought a new battery, but that didn't make any difference to the stalling problem.
It would be interesting to know what your problem is.
Maybe mine is just a simple idling too low problem. It just got serviced the other week maybe they stuffed it.
Ok ive done some testing/thinking, and i have found that the FCPM (fuel control power module) switches the fuel pump to a resister in series with the pump, which slows down the pump at idle. No one ive talked to has been able to work out or tell me why nissan did this and most people who have had experience with it, just short out the resistor and dont worry about it. If they install an aftermarket pump, they just wire it directly to the fuel relay. Makes any tuning easier. its just a pain to work with otherwise.
So im going to do this also and if that doesnt work, I nonticed also, that just openign the throttle slightly makes it idle fine, so why not just dupicate that.
What i mean is, let more air in and adjust the voltage on the input to the ECU from the throttle position sensor, up a bit.
Say, put some resistors into the wiring (with trail and error of course to get the right adjustment, probably put some variable resistors in) so even if the throttle closes off or the air flow goes to zero, the ECU will always put enough fuel in to keep a stable idle. Bit like a "no go" zone in the map.
I can put the TPS back to factory position, let the AAC work again and wire in a resistor to stop the fuel level getting too low.
I have also got my second set of injectors getting cleaned this afternoon and am waiting to see what results that brings along.
I could also using resistor networks, raise slightly the voltage of the AFM output too.
Eventually I will get this problem sorted, its just that its going to take more than just a part swap to fix it, like normal. Ill proabaly install a small box with two variable resistors (black box with knobs) on the dash temporary to play with to sort it.
Edited by stimps
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
