So i got rid of my Maxima and replaced it with this bad boy. For the price it was going for, its condition and the options it has, I couldn't say no.
Its an 89 model, RB20E Auto, 76xxx kms seem genuine.
Panels are all good bar one (pending fix), the paint is shit especially on the bumpers and there's a few spots of rust.
Runs mint though, has been looked after really well, the air con still works.
Needed to pick myself up a nice car to cruise around in. Having a work car is awesome, but a manual hilux with radio only certainly never fits when you want to go for a drive late at night or on the weekend.
Options include:
Factory sunroof w/ shade + logo
ABS (unusual for pre - xNA31s)
Optional fabric interior (still pretty bleh, but better than standard)
Extra bling lining down the doors.
I don't care what you say - I like it :P
Edited by Nic_A31
https://www.sau.com.au/forums/topic/321677-my-other-new-ceffy/
Haha a few people have said the same thing...
The sunroof made my first one more appealing to purchase, and I aquired this one by posting a WTB for a Cefiro rolling shell when I was paranoid about the other one being bent...guy messaged me said he had one with a sunroof already, perfect win.
Aye lads, I be holding a proposition for ye,
How about these rim for the boat
Couple of hundred, and about 800 by the time its set sail across the seven sea's and landed at my door.
DO EEEET!!!
I have replicas of these and they look fantastic with the right offset. Pity mine isn't lowered.
I think Dan should sell me his jap dishies, since they've been in his signature for soo long:
haha, so true :yes:
also spacers are for pus-sies, those stich type meshies need more lip on the rear for the goods
check ns.com vip rims are usually floating around
Aquired R32 4 pot calipers, slotted rotors (multi stud pattern), Standard R33 rotors, R33 calipers and R34 5 stud rear hubs w/ bearings.
Pending brake lines and rego before they go on, I test fitted the front calipers with the stockies and 3mm slip on spacers.
IT CLEARS....JUST. The rim somehow free-spins without grinding...but have a look at this pic, Definately not going to risk it, there'd be less than a 0.25mm clearance in there....need bigger spacers or different rims, or wait till I turn the front 5 stud .... but since i got multistud rotors, I can retain 4 stud and just use some slip on spacers in the mean time.
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
